Profile
soulza
Profile
hi just joined other day , my upstream is half of what it should can i have this looked at please, i believe this is profiled wrong and not a fault.
jtk
Re: Profile
If you look at some of the other messages here, you will see this is a common complaint. I have recently seen a statement in some of Plusnets blurb that it could take a while for the profile to be set ( 2 days I think was mentioned ). However if you ring the support number, they will do it while you are on the phone.
You may also get a response from one of the guys here who can do the same thing.
Re: Profile
Upstream speeds aren't governed by a profile in the same way downstream ones are, so don't generally suffer from the common "profile not updated" issue after installation of FTTC.
If there is a difference, it will need investigating further
OP: if you wish for any of your fellow users to offer help, you'll need to give a few more details of what you know, what you expect, and what you've tried to check/fix things.
Plusnet Customer
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
Fixes: 78
Re: Profile
Hi soulza,
You're hunch was right. I've just updated some settings on your account (the "provisioned product") which was set incorrectly.
Sorry about that!
 Adam Walker
