Profile upgrade check
- Profile upgrade check
27-06-2015 6:56 PM
About one month ago (roughly) I upgraded my mothers account from the Unlimited fibre package to Unlimited Fibre extra but haven't seen an increase in speed since the last billing date which is when it should have changed, the account currently says estimated line speed is 57Mbps and current line speed is 16Mbps.
Estimated line speed:
57Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2015-05-29 17:37:38
Current line speed:
16 Mb
Would anyone be able to have a quick check on this.
Thanks,
Jake
Re: Profile upgrade check
27-06-2015 7:02 PM
Can you get your mother to run this test and report the results http://www.speedtest.btwholesale.com/PerformanceTesterWS/diagnostics.do
27-06-2015 7:09 PM
this will show what the profile is set to at BTWs end, ignore the red writing run the test when it's finished run further diagnostics and post here what it says.
it may well be that the plusnet profile hasn't updated to match the BTW one it should happen automatically but that doesn't always seem to happen.
edit.. oldjim beat me to it ever the pro
27-06-2015 7:11 PM
This is the first diagnostic test I ran.
1. Best Effort Test: -provides background information.
Download Speed
14.05 Mbps
0 Mbps 16.02 Mbps
Max Achievable Speed
Download speedachieved during the test was - 14.05 Mbps
For your connection, the acceptable range of speedsis 40 Mbps-16.02 Mbps .
Additional Information:
IP Profile for your line is - 16.02 Mbps
Upload Speed
3.39 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 3.39Mbps
27-06-2015 7:16 PM
Check what this says about speeds http://www.dslchecker.bt.com/adsl/ADSLChecker.TelephoneNumberOutput and, assuming that it says something a lot higher than you are getting, raise a fault here https://faults.plus.net
If it says something in line with the profile from the BT test then you have been mis-sold the upgrade to fibre extra and Plusnet will sort it
Note that test shows that you are on fibre 40/20 not fibre extra 80/20
Was that before the product change
27-06-2015 7:23 PM
High Low High Low
FTTC Range A (Clean) 77.6 57.9 20 18.9 -- Available
FTTC Range B (Impacted) 70 41.3 20 12.2 -- Available
WBC ADSL 2+ Up to 1 -- 1 to 3.5 Available
ADSL Max Up to 1 -- 0.75 to 2.5 Available
WBC Fixed Rate 0.5 -- -- Available
Other Offerings
Fibre Multicast -- -- -- Available
Copper Multicast -- -- -- Available
27-06-2015 7:25 PM
Edit: I've got the fault page open but haven't sent it yet just in case.
27-06-2015 7:39 PM
27-06-2015 7:40 PM
29-06-2015 9:33 AM
