Profile update requested
faybill
I  recently upgraded to 78/20 but my actual speed of 47/14 is nowhere near the estimate, I contacted chat yesterday and asked him to check my set up, he said I was wrongly on the 50 profile and that he corrected it to 80 and to reboot the router after 10 minutes
I have done this yesterday and this morning as well but still getting 47/14, could someone please check that my profile has changed to 80, or am I doing something wrong.
14 REPLIES 14
Starmans
Re: Profile update requested
What does BTW ADSL Checker state your line supports, and what are PN reporting your line profile as.
faybill
54>>71
Thank you for your call today. Please keep a copy of this e-mail for your records. As discussed, I’ve made the following changes to your Plusnet service: Your estimated line speed range is from 54Mbps - 71Mbps, however this may vary due to the distance from
Estimated line speed:71Mb (This may vary between 54Mb and 71.3Mb) - Checked on 2016-07-21 17:16:31Current line speed:78 Mb
faybill
the guy yesterday said the profile was wrongly 50 and that he had reset it to 80
FAQ
Results Image not loaded
1. Best Effort Test: -provides background information.
  Download Speed
  47.77 Mbps
0 Mbps 49.42 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 47.77 Mbps
 For your connection, the acceptable range of speedsis 34.59 Mbps-49.42 Mbps .
 Additional Information:
 IP Profile for your line is - 49.42 Mbps
  Upload Speed
  12.21 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 12.21Mbps
Starmans
Sorry are you saying that the BTW Checker states your line only supports 54Mb? if that's the case then that is all you'll get unfortunately.
If you could capture a screenshot of the BTW Checker and paste it here to end any confusion. Remember to edit your phone number.
faybill
faybill
the btw checker says my"connection speed" is 49.42 surely this governed by the speed being supplied by plusnet and was borne out by the chat guy saying it was wrongly set at 50
faybill
went onto chat and asked to check--he came up with this
OK, BT network issue is being detected that is causing the speed to synchronise at 51Mbps, I am just going to get this reported up now.
will update as actioned by plusnet
Chris
Legend
Fixes: 169
Afraid not, the speed shown there on the speedtest is based on the sync speed directly from your modem/router to the cabinet.
The person you spoke to on chat did the wrong thing, and from the sound of it confused matters to. The only thing they changed is a profile on our side, which does not at all affect the sync speed of your line. This is what is now showing as 78Mb.
As you're below the estimate it'll need reporting to us as a speed fault at https://faults.plus.net
Chris
Legend
Fixes: 169
I can see there's a fault open and reported, thanks.
Looking further at your account I can see there were quite a few disconnections yesterday:
Testing your line is erroring, so it has already been reported through to our suppliers for more investigation.
faybill
I restarted my router a few times yesterday pm  one or two at the most today
I will not restart unless told to
Chris
Legend
Fixes: 169
Try to keep router restarts to a minimum, if the line is seen as unstable then it can cause the speed to reduce.
faybill
thankfully no reductions as yet   will not restart again
faybill
my PC is connected to the hub one via an access point(old router via cat6 Ethernet cable)
hub one(lan1)>>>cat6>>>plusnet router(access)lan1>>>lan2>>> cat 6>>>pc
this worked ok before and it is unchanged set up from previous, I could run the cable without going thro the access point
Mav
Fixes: 514
Moderator's note by Mike (Mav)
Empty post removed
Forum Moderator and Customer
