Profile update request
- Re: Profile update request
17-03-2015 12:20 PM
As G.INP is rolling out at the moment, my cab was updated 3 days ago. As expected, this caused a modem re-sync:
After this my Plusnet profile was reduced from 80 Mb to 65.4 Mb.
Please can you change the profile back to 80 Mb. Many thanks.
Before:
After:
Before:
After:
Message 1 of 6
(782 Views)
5 REPLIES 5
17-03-2015 12:22 PM
Message 2 of 6
(482 Views)
17-03-2015 12:33 PM
Many thanks for your quick response. I have restarted the PPP session and the speeds are back up, but not quite as fast as before.
I see that my profile is now 78 Mb.
Can it be set to 80 Mb like it was before? My line handled it fine and it does make a noticable difference (as discussed here).
Thanks!
Thanks!
Message 3 of 6
(482 Views)
17-03-2015 3:15 PM
Hi
I have a similar issue, my line profile has been reduced to 55mb from 78mb can it be reversed please!
Message 4 of 6
(482 Views)
17-03-2015 3:27 PM
@Peebles
That's the highest the profile can go I'm afraid. We can't set that any higher
@mlmclaren
As per your other thread your profiles are matching. Your issue is with the actual sync speed rather then the profiles
@mlmclaren
Message 5 of 6
(482 Views)
17-03-2015 4:27 PM
As the original question has been answered the subsequent posts have been split off and merged with mlmclaren's original thread http://community.plus.net/forum/index.php/topic,137362.0.html
This topic is now locked
Message 6 of 6
(482 Views)
