Profile speed should be higher
mojorisin
Can my profile been given a nudge please showing as 45.2 but download tests show about 20mb down and 10mb up
I used to get high 50s early 60s down and 15 to 17 up
Fixes: 167
Re: Profile speed should be higher
Your profile is correct at 45.2Mbps, have you tried a single disconnect/reconnect?
 Chris Parr
 Plusnet Staff
mojorisin
My profile is way lower than what it should be used to be in the high 60s
speedtest results are poor on download used to be in the 50s and 60s and upload about 16
mojorisin
after a restart this morning
better but still not what i had been getting before
Fixes: 214
The profile on our side is correct, however it does look like the sync speeds are a little low.
I'd recommend going through troubleshooting and raising a fault at http://faults.plus.net
 Harry Beesley
mojorisin
Ran the BT test results show speeds should be higher
plusnet ticket number 123054431
attached BT test
IP Profile for the line showing as 45.4 this is far too low usually high 60s
etdsaunders
Fixes: 7
This either a fault, or possibly crosstalk. I hope it's a line fault, have plusnet tested the line for faults?
Raspberry Pi enthusiast!
If you Like it, give it a Thumbs Up
Fixes: 214
When I checked the line on my previous message it didn't flag up any faults but the sync speed was around 45.
 Harry Beesley
