Profile error!
- Profile error!
Profile error!
13-10-2014 5:57 PM
Thanks in advance 😛
Re: Profile error!
13-10-2014 6:32 PM
I've updated the speed profile for you on our side as your line is testing at 80mbps synch - which is smashing. If you haven't got a faster speed already, you'll just need to reset the connection.
The speed cap was caused by an update from your exchange though, probably due to errors on the line, so there's likely an underlying issue we need to look at. I can see that you've raised a fault through the website so I'd definitely monitor the line for now and let them run some more tests later in the week.
Cheers,
Aled
Re: Profile error!
13-10-2014 6:33 PM
Re: Profile error!
13-10-2014 6:34 PM
Re: Profile error!
13-10-2014 6:43 PM
Re: Profile error!
13-10-2014 6:52 PM
If you can arrange for Pink Floyd to be Sheffield based that I can definitely get that done for you
davidoneman - your connection seems to be a similar story so I've bumped the connection profile up to 40mbps given that your synch is OK. Again, just reset the connection if you haven't seen a bump up already.
You've also got a fault ticket open so I'd monitor for now and let the Faults Team have a look later in the week.
Cheers,
Aled
Re: Profile error!
13-10-2014 6:52 PM
Re: Profile error!
13-10-2014 8:17 PM
Re: Profile error!
13-10-2014 8:32 PM
Re: Profile error!
13-10-2014 8:51 PM
Re: Profile error!
14-10-2014 12:17 AM
Re: Profile error!
14-10-2014 12:09 PM
