Profile does not match line sync
Haffoc
Currently, https://portal.plus.net/my.html?action=stable_rate shows my profile as 68.8Mb. My router is showing my connection as syncing at 75Mb/15Mb.
Could someone please look at this and give my Plusnet profile a bump?
Speedtest.net is currently showing a speed of 66Mb while historically it has always been around the 71/72Mb mark.
Surely my current line speed shown in the member centre should be the same as or close to my actual sync speed? I'd expect a sync of 75Mb to equate to somewhere around 69-71Mb throughput.
Fixes: 21
Re: Profile does not match line sync
What does the BT speedtester further diagnostics give for the IP Profile?
On FTTC, the IP profile is usually about 96.8% of the line rate, but on a "Retransmission High" profile, it's a lower percentage, about 91% or 92%.
Haffoc
Damn, knew there was something I forget to check.
BT Speedtest shows acceptable range of 40-68.98 and shows IP Profile as 68.98Mb - which matches what the member centre shows 68.8Mb. So it seems it's the BT profile that is limiting my connection and causing a 6-7Mb drop between sync and actual speed.
Fixes: 21
I think the 68.98Mb profile is correct, it's probably making allowances for the expected loss of throughput from retransmissions on the "Retransmission High" profile.
Haffoc
I used to be Retransmission Low
This is from February this year
"0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off"
I know it's a long time back but this was from the last time I used Speedtest.net
21/12/2015
6:45 PM
8
70.08
19.21
~ 50
Maidenhead
XILO
PlusNet
28/6/2015
2:50 PM
9
69.89
17.41
~ 50
Maidenhead
XILO
PlusNet
21/6/2015
10:28 PM
11
69.00
17.41
~ 50
Maidenhead
XILO
PlusNet
21/6/2015
9:07 AM
10
69.01
17.40
~ 50
Maidenhead
XILO
PlusNet
19/6/2015
9:57 PM
9
69.00
17.43
~ 50
Maidenhead
XILO
PlusNet
16/6/2015
2:19 PM
16
68.40
17.42
~ 50
Maidenhead
XILO
PlusNet
15/6/2015
5:06 PM
As you can see my line speed has nearly always been 68-71Mb though it did drop to 62Mb for a couple of weeks in February.
Fixes: 216
I've just updated your profile and dropped your session so you should be able to get higher speeds.
 Matthew Wheeler
Haffoc
Thanks, that's helped.
