Profile bump please
- Profile bump please
Profile bump please
18-01-2020 8:09 PM
I've raised a support ticket previously but got given the usual "try using the master socket" line.
This is an issue that I've had numerous times in the past so would appreciate if it could be looked into a bit closer. My line syncs at the maximum it can (73999Kb/s) but every now and again I encounter slower speeds than I should be getting. At the moment it tops out at exactly 66Mb/s every time, so once again it looks like my profile is getting restricted again.
Could this be double checked please? And if there's any way to force it to stay at an unrestricted/max level that'd be great.
Cheers!
Re: Profile bump please
19-01-2020 8:58 AM - edited 19-01-2020 9:02 AM
Hello @dfunked you can check your IP Profile status in the diagnostics within the BT Wholesale Broadband Performance Test.
Your line IP Profile status is at the bottom of the box beneath the download and upload information.
If a fault is detected, the BTW diagnostics will show a red bar and will say "Please contact your ISP for further assistance with these results." at the bottom of this page.
Hope this helps. Kind regards.
19-01-2020 9:29 AM
Thanks crimson. No fault detected, and if I click further diagnostics I just get the below. I've tried a few times and results are always in the region of 63-65Mb/s
1. Downstream Test:
Download Speed : 63.46 Mbps
2. Upstream Test:
Upload Speed : 14.96 Mbps
Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information.
19-01-2020 6:32 PM - edited 19-01-2020 6:44 PM
Hello @dfunked it appears that the BT Wholesale Broadband Performance Test is being used by many customers today and you were not given the option to use the BTW diagnostic test. An example is posted so you can see what happens when the BTW diagnostic result displays a red bar and declares a fault in the text. Most telephone line and broadband providers will investigate when a fault is declared in your BTW diagnostic result. Please try again when you are ready.
If your device has Windows, click on the screen image, followed by pressing the [alt] + [prt sc sysrq] keys to capture, then paste into your paint application so that this can be saved as a jpg file. To import this jpg file into your post, click on the Insert Photos icon in the header. Hope this helps. Kind regards.
20-01-2020 7:48 PM - edited 20-01-2020 7:49 PM
Hi @dfunked,
I'm sorry that your speed has dropped and for any inconvenience that this is causing you. I've tested your line and the test shows that your profile is currently set to 0.128M-74M, which is within the estimates for your line. However, the test hasn't been able to detect your current downstream speed at all, which suggests that something is out of place here that will need further investigation.
GEA Test Detail | |||
Circuit ID | NA | Service ID | BBEUXXXXXXXX |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
Description | GEA service test completed and no fault found . | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 0.0 Mbps | ||||
Upstream Speed | 20.0 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Not Detected | ||||
Radio Frequency Ingress | Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Estimated Line Length In Metres | 71.6 | ||||
Upstream Rate Assessment | Very Good | ||||
Downstream Rate Assessment | Low | ||||
Interference Pattern | Regular Interference Observed Daily | ||||
Service Impact | No Impact Observed | ||||
Interference Duration Longest Occurrence | From12:15to15:45 | ||||
Interference Location | Customer Premise | ||||
Interference Observed In Days | 13 | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL | ||||
Current 15Min Bin Retrains | 0 | ||||
Last 15Min Bin Retrains | 0 | ||||
DP Type | External | ||||
Profile Name | 0.128M-74M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off | ||||
Time Stamp | 2020-01-07T19:45:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 73.9 Mbps | 73.9 Mbps | 73.9 Mbps |
Up Stream Line Rate | 20.0 Mbps | 20.0 Mbps | 20.0 Mbps |
Up Time | 897.0 Sec | 900.0 Sec | 899.9 Sec |
Retrains | 0.0 | 0.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2020-01-20T19:11:27Z | 2020-01-20T19:26:27Z |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
I'd recommend starting with basic checks here. If these checks don't resolve the problem, the next step would be to connect your router directly to the test socket, which is under the faceplate of your master socket and seeing if the connection stabilises. This rules out internal wiring, face plates and extension sockets as being the cause. Please see the following guide for instructions on how to connect to the test socket.
Please let us know how it goes.
21-01-2020 5:34 PM - edited 21-01-2020 5:36 PM
Thanks to @EmilyD for posting the results of the Generic Ethernet Access (GEA) service test complete with acknowledgement that something is out of place that will need further investigation.
We would like to see more data from @dfunked to check if your line has a fault to investigate.
Please obtain and post an image of your BTW diagnostic result from your BT Wholesale Broadband Performance Test.
Could you also conduct a BT Broadband Availability Checker to see what speed your line supports. This test uses your telephone number. So please remember not to include any personal information when posting the result. I have included an example of an ADSL check result.
Thank you in anticipation for your continued interaction. Kind regards.
21-01-2020 8:32 PM
22-01-2020 2:17 AM
Hello @dfunked thank you for conducting the two line checks.
The ADSL check result says that your line has been set up to give a download speed of about 80Mbps, with very little variation. There is no reported VDSL Range A to B difference so your line is exceptionally free of wiring issues or detectable copper line quality problems. This is a very good result.
The BTW performance check's seemingly persistent refusal to provide your line's full diagnostic result is very perplexing. The Generic Ethernet Access (GEA) service test conducted by @EmilyD refused to provide your downstream speed result. The absence of full data provision by these two checks is sufficient for you to raise a fault for further investigation.
Your comment about giving the @EmilyD suggested checks a try when you have a chance is your bad. Having raised another profile bump request with your earlier profile bump request flagged as fixed, you should have removed your master socket's faceplate and plugged your Hub directly into the master socket's test socket.
23-01-2020 8:58 PM
OK... I'm now plugged directly into the master socket with absolutely no change (appreciate that I should've done it sooner, but it's an absolute nightmare to get to the socket)
BTW test is still giving the same results with no option to take it further. Any speedtest I do is still topping out at 66Mb/s so I guess this needs to go forward as a fault. It really does seem to be something outside of my house that's limiting it.
@EmilyD - could you take it forward please?
I've left it plugged into the master socket for now if that helps.
1. Downstream Test:
Download Speed : 64.4 Mbps
2. Upstream Test:
Upload Speed : 16.59 Mbps
24-01-2020 3:16 PM
24-01-2020 9:35 PM
Cheers @Mads - fault has been raised now
25-01-2020 3:40 PM - edited 25-01-2020 3:40 PM
Thanks for getting back to us @dfunked
I've looked into this for you and I can see that the bRAS profile on the line is set at 70.3mbps which is 96% of your sync speed that's is correct for a line with retransmission on and this would explain your throughput of 64 to 66mbps.
It'd be near nigh on impossible to get a throughput of exactly the bRAS profile. If your sync speed was higher this would increase the bRAS profile rate and in turn your throughput.
As your sync speed is artificially restricted by the DLM(Dynamic Line Management) software at the cabinet I've requested a DLM reset which should go through within the next 3 working days and hopefully increase your speeds.
I hope this helps.
28-01-2020 2:00 PM
Cheers @Gandalf
Somewhere along the way between swapping cables around for quiet line tests/master socket etc my sync seems to have dropped to 66999Kb/s and speedtests are now around 63Mb/s
Hopefully this gives it a kick back upwards.
29-01-2020 1:56 PM
I've re-added you back to the DLM reset tracker for another reset which should go through again within the next 3 working days. We may need to arrange an engineer to investigate further if this happens again.
03-02-2020 12:46 PM
Afternoon @dfunked I'm happy to confirm your line has been reset and your sync speed has improved to 76mbps which is correct for a line with retransmission on as this DLM setting will be consuming some of the speed to keep any errors at bay.
If there's anything else you'd need help with, please feel free to let us know.
