Profile band check please
FIXED- Subscribe to RSS Feed
- Profile band check please
22-05-2018 12:26 PM - edited 22-05-2018 12:38 PM
Hello!
I just wanted to check if my line has been banded as I have been playing around with swapping the old ECI modem with the Business Smart Hub.
After all these years with Plusnet you could finally request remote DLM resets, if my profile is banded, I would be grateful for this I was always stuck on a 68.11Mbps profile for at-least two years until I swapped over to this Smart Hub and eventually got a higher data rate but a lower bras profile.
According to BT BRAS:
Number: 0208#######
The current Downstream BRAS rate is: 67.87 Mbps
The current Upstream BRAS rate is: 20 Mbps
My Smart Hub stats:
Firmware version: SG4B1B008146
18-May-20181.01.91.53 Days, 0 Hours 44 Minutes 15 Seconds15.00 Mbps / 70.19 Mbps26150 / 7111913.9 dB / 6.3 dB0 dB / 13.7 dB0 dB / 13.7 dB101G_993_2_ANNEX_BFast Path
Swiss Army Knife for diagnosing all your issues
Fixed! Go to the fix.
Re: Profile band check please
24-05-2018 5:44 PM - edited 24-05-2018 5:49 PM
Hello?
Dead silent over here. Staff seem to reply quicker to new threads for profile resets and seem to skip mine.
Ip profile still set at 67.87 Mbps, data rate is at 70.19 Mbps. This is fine?
24-05-2018 5:55 PM
Your IP profile should be 96.8% of your data rate - it is!
24-05-2018 5:59 PM
@JayG Thanks then, I suspected there was some overhead percentage being taken into account to prevent some form of data loss when the line is maximised.
Didn't have any reply from plusnet so didn't know.
I had the same data rate but a profile of 68.11Mbps which is what has concerned me but a couple of Mb wouldn't do anything tbh.
