Profile Nudge Please
markeagles1973
Sync 40000 profile is 34.8 , not sure what 38mb profile is 37.7? 38?
Fixes: 5
Re: Profile Nudge Please
I've made the change for you. I've put it on 40Mbit, and it will change down as appropriate automatically.
Drop the session and restart and you'll see the new speeds.
 Tony T
markeagles1973
37 is that correct ?.. As in drop the PPPOE session not the OR Modem connection ?
Thanks anyway Smiley
Fixes: 5
I can't see the actual profile, only the sync rate. It's our side I've changed rather than BT's which so I only needed you to re-auth.
 Tony T
markeagles1973
Estimated line speed:
Current line speed:
37 Mb
Thats PN profile ? or should it be 38 , not that i don't mind been a long time since i have seen it this high
Fixes: 5
Yes, but I'm unable to change it to 38.
 Tony T
markeagles1973
Wow no 38mb ? BT Profile is
Download speedachieved during the test was - 37.47 Mbps
For your connection, the acceptable range of speedsis 20 Mbps-38.67 Mbps .
Additional Information:
IP Profile for your line is - 38.67 Mbps
Upload speed achieved during the test was - 6.92Mbps
Upstream Rate IP profile on your line is - 10 Mbps
Is that a PN system fault then
Fixes: 5
There is, because I've just changed another account to that profile (in my last post). For some reason, not on your account.
 Tony T
markeagles1973
Can we have a look at this please , i have always wondered why there was no estimate on my account either .
Fixes: 204
Your profile is at 38.6 now from what I can see?
The estimate should be showing now although it will be your estimate for ADSL rather than FTTC.
 Matthew Wheeler
