Problems with Internet
sharon468
For about a week I've been having issues with my internet.
Mainly it'll disconnect for a few minutes and reconnect which is annoying as hell.
I've had PlusNet broadband for ages but I was using a BT HomeHub 4 as I've been told the PlusNet router is useless and I NEVER had any problems.
Now a week ago I had to swap to the PlusNet Hub One because I was getting in fibre optic and ever since then I have constant issues with disconnects. A couple of days ago it went down, I was connected but could not connect to the internet irregardless of what I done, be it restart or reset.
Why does your router SUUCK so much?!
SpendLessTime
Aspiring Hero
Fixes: 63
Re: Problems with Internet
@sharon468
If you have Plusnet Unlimited Fibre (the speeds are 40Mbps down and 2Mbps up)  then you maybe seeing the issue reported here https://community.plus.net/t5/Fibre-Broadband/Plusnet-fibre-broadband-does-not-cope-with-uploads-and...
If so, just post there and ask for @bobpullen
sharon468
I have Fibre Extra Broadband, but thanks for replying.
