Problems tonight 19th june? single and multi thread tests dire
- Problems tonight 19th june? single and multi threa...
19-06-2016 9:56 PM
Since about 9pm till now speeds have dropped, usually 34 down, plus there is some loss on my graph since 9pm
http://www.thinkbroadband.com/ping/share-large/8dec7cf519beda3b43f06c9508b6ab21.pngTried the usual gateway hop with some differnce between them, but all suffering unless I have a fault
Re: Problems tonight 19th june? single and multi thread tests dire
19-06-2016 11:21 PM - edited 19-06-2016 11:22 PM
20-06-2016 12:00 AM
Im also having issues ive lost connection twice now and my internet pages are failing to load, im guessing maybe it could have somthing to do with this http://usertools.plus.net/status/archive/1466188783.htm
20-06-2016 1:14 AM
work isnt due to start on my dial code till 22nd https://status.zen.co.uk/broadband/maintenance-outage-details.aspx?reference=312254
20-06-2016 10:35 AM
Gus wrote: fyi time stamp on the test is out by one hour, looks like TBB still think its winter
<pedant mode> The time stamp says 22:20 GMT and is correct. </pedant mode>
20-06-2016 10:52 AM
nope did the test then posted it last night around 11.30pm not 1030pm
20-06-2016 11:42 AM
But that was 11:30 pm BST which *is* 22:30 GMT
(I did say I was being pedantic )
20-06-2016 12:23 PM
There was no reported issues last night, so I'm not entirely certain what happened.
Testing your line and it looks ok at the moment, slightly the lower side of the fibre estimate. Are you still having issues?
20-06-2016 12:59 PM
No problems currently, since this connection went live its averaged around 34mbit mark. Unless there was problems last night either a fault or my cabinet is already over full again. Recent house move and It had to have capacity added for my order to go through.
20-06-2016 1:02 PM
Certainly not forgotten that, it went on for a long time. Let us know if the issues come back.
20-06-2016 9:16 PM
starting to dip again tonight, tried at 9.05pm and just now with similar results
21-06-2016 8:55 PM - edited 21-06-2016 10:06 PM
Same again tonight on single thread, now the joys of a fault ticket when nothing can be tested as its late at night when you no longer Officially work.
edit phoned in and found out you work at nights again, but not really. Could someone pick this up and raise a fault as the tech I spoke to got stuck in the headlights of the BT speed test can't be wrong!
Packet loss on my TBB graph and single thread testing dipping as low of 2mbit to a dazzling 6mbit, makes for a wonderful nights gaming.
21-06-2016 11:33 PM
22-06-2016 9:21 PM
and it starts again, cant watch any twitchtv streams without caching, can't even attempt to host any p2p games in warframe and BT speed test once again says its all fine
26-06-2016 8:04 PM
Same problem tonight but also went from 37mbit down / 9up too 44 down and 9 up after some maintenance last night 25/6 th between 2am and 5am going by my TBB graph.
achieved during the test was - 44.87 Mbps
For your connection, the acceptable range of speeds is 32.93 Mbps-47.04 Mbps .
Additional Information:
IP Profile for your line is - 47.04 Mbps
