Problem with Plusnet hub
- Re: Problem with Plusnet hub
16-01-2019 9:13 AM
I had a few issues with my Plusnet Hub so decided to reset it using a pin at the back.
Since its come back on I cannot access the internet.
The router is connected and the light is blue at the front however I'm just getting sign in each time I try to connect and a question mark at the side of the Wi-Fi on my mobile devices.
I'm currently away from home until later this afternoon but the router is on , any help would be greatly appreciated.
Message 1 of 7
(1,162 Views)
6 REPLIES 6
16-01-2019 11:11 AM - edited 16-01-2019 11:12 AM
Just to add I tried resetting it twice but with no joy.
Message 2 of 7
(1,145 Views)
16-01-2019 12:53 PM
Any suggestions ?
Message 3 of 7
(1,131 Views)
16-01-2019 1:35 PM
Did you re-enter your username@plusdsl.net and password in the settings?
BT FTTP 500 + pfSense + Uniquiti Unifi 6 Pro
16-01-2019 3:10 PM
16-01-2019 3:13 PM
Yes excellent support over the phone. Thanks to those who responded we are back online now.
16-01-2019 3:20 PM
