Problem With Signal?
FIXED- Subscribe to RSS Feed
- Re: Problem With Signal?
22-10-2019 1:36 AM
Fixed! Go to the fix.
22-10-2019 1:51 AM
22-10-2019 3:02 AM
22-10-2019 11:48 AM
Hi @Jayb1976, sorry to hear you're having broadband issues.
I've had a check of the connection and there definitely seems to be something out of place somewhere as we can see the disconnections from this end, although our tests aren't picking up exactly what's causing the issue so we will have to do some troubleshooting to start ruling things out.
I'd recommend starting with basic checks here
And if that doesn't help the next thing would be to rule your internal wiring out by plugging the connection into your test socket which is under the faceplate of your master socket and seeing if the drops stop. This rules out internal wiring, face plates and extension sockets as being the cause. How to locate the test socket and set your connection into it can be found here
If the problem still persists from here we will go down the route of sending an engineer, let us know once you've done the checks so we can progress the fault for you.
22-10-2019 11:50 AM
Hi @Nikkishep82,
I can see that you are currently speaking to one of our colleagues at the technical department.
Let us know please how it goes.
22-10-2019 1:33 PM
I reset the channels back to the smart settings last night to see if that helped. It seems to have stabilised the signal at the moment.
I've carried out your checks before removing the faceplate on the master socket. Am I to leave my router attached to the test socket for a couple of days?
The speed I'm receiving is no different in the test socket to when I use the faceplate. I'm only getting roughly 30mb/s upstairs in my house and I'm unable to move the router anywhere else. This speed is an improvement since I went to fibre unlimited extra last week as before I was only receiving about 20mb/s.
Does the connection still need time to settle?
Does the
22-10-2019 1:51 PM
There are two issues here:
1. If Plusnet are seeing drops then that is nothing to do with how good your wireless performance is. By plugging in to the test socket you are eliminating any internal wiring so if it no longer drops then you have a problem with your internal wiring, which lies outside of the responsibility of Plusnet. So leave it in the test socket for several days to see if the drops go away.
2. The first thing to try when having problems with your wireless is to separate the 2.4 and 5GHz bands, see https://community.plus.net/t5/My-Router/2-4ghz-and-or-5ghz-best-practice/m-p/1351966#M840 Try each band in turn and use the best. If that doesn't work then come back for further advice.
22-10-2019 2:05 PM
Secondly using the test socket has made no difference to my performance from using the regular socket. I was only really enquiring how long I was to leave it in the test socket.
I only moved onto Fibre unlimited extra a few days ago, so I presume there is a period of days for everything to settle.
22-10-2019 2:09 PM - edited 22-10-2019 2:15 PM
If you want to believe that changing your smart band settings cures line drops then fair enough.
If you are happy with paying for Fibre extra and only getting 30Mbps from you wireless connection then again, ignore my previous post.
For the record, I am just another Plusnet customer trying to help.
22-10-2019 2:12 PM
22-10-2019 2:19 PM
22-10-2019 4:34 PM
Hi @Jayb1976
We wouldn't be able to guarantee you a Wireless signal upstairs (or anywhere for that matter, mores the pity) - a Wired connection is the only type which we are able to guarantee on both speeds and stability.
Changing you Wireless channels and splitting the frequencies are the best things we can advise on our router to ensure you are getting the best possible Wireless experience.
Some people have found that Power Line Adapters, alternate Routers, WiFi Boosters et al. have helped them achieve their desired Wireless connections. Please note, however, that we are unable to offer assistance with 3rd party tech within your local network beyond providing authentication credentials.
Kind Regards,
MoR
22-10-2019 10:14 PM
23-10-2019 11:19 AM
