Problem Setting up TP-Link AC1750
- Problem Setting up TP-Link AC1750
23-01-2015 9:48 PM
Can anyone give me any pointers with regards to setting up a TP-Link Dual Band AC1750 Router.
I can see the Router on my Network but it won't connect to the Internet
Re: Problem Setting up TP-Link AC1750
24-01-2015 12:41 AM
Connect the OR modem to the internet port on the Tp1750
Then open a browser and click on http://tplinklogin.net
User: admin
Pass: admin
Select PPPoE/Russian PPPoE
Then set up the wireless. Select the defaults for the time being if your unsure and we can guide you further on here
24-01-2015 8:13 AM
This is becoming a real head scratcher.
I have done exactly as you describe but to no avail. It keeps saying no Internet access.
In the configuration browser under WAN section of the Network it shows all the fields with zeros. And it just says connecting but never does.
24-01-2015 9:04 AM
eg. myusername@plusdsl.net
24-01-2015 10:28 AM
You were spot on I was using the wrong credentials
It's working fine now
24-01-2015 2:46 PM
30-01-2015 12:38 PM
As you can see from this thread I invested in a better router and the wireless does seem greatly improved.
However I have decided to hard wire my Desktop PC with a 10M ethernet cable and it says on the adapter that its running at 1GBPS but it takes about 20 seconds to load a web page an eBay page or Auto trader adverts for example.
Can anyone point me in the right direction using absolute layman speak please?
03-02-2015 6:22 PM
03-02-2015 7:07 PM
If the above doesn't help:
Assuming it's a windows PC can you open a command prompt, enter the following command and post the result.
ipconfig /all
( to open a command prompt in windows <windows key + r> in the box which pops up enter cmd ,
04-02-2015 11:10 AM
Yes, you are correct I'm using a Windows PC running Windows 8
I have tried following your instructions but upon hitting enter the information flashs on the screen for a fraction of a second and disappears
04-02-2015 11:42 AM
Open a command prompt in windows <windows key + r> in the box which pops up enter "cmd" without quotes. -- I'm guessing you tried entering ipconfig /all there.
A black window will now pop up, it's this which is called a command prompt.
Now in this black window enter "ipconfig /all" without quotes and press enter.
Did you ensure the PC doesn't have wifi enabled at the same time you're using ethernet?
You can turn off wifi by left clicking on the wifi icon on the bottom right of the screen that will give the option to turn off wifi (you may need to first press the windows key to get out of the metro screen)
04-02-2015 11:52 AM
Microsoft Windows [Version 6.3.9600]
(c) 2013 Microsoft Corporation. All rights reserved.
C:\Users\Darren>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Darren
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
Physical Address. . . . . . . . . : EC-A8-6B-6D-0C-26
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::2896:c2a9:5592:ffa7%4(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.105(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 04 February 2015 10:32:58
Lease Expires . . . . . . . . . . : 04 February 2015 13:32:58
Default Gateway . . . . . . . . . : 192.168.0.1
DHCP Server . . . . . . . . . . . : 192.168.0.1
DHCPv6 IAID . . . . . . . . . . . : 367831147
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-17-E9-F7-84-74-E5-43-2E-47-0F
DNS Servers . . . . . . . . . . . : 192.168.0.1
NetBIOS over Tcpip. . . . . . . . : Enabled
C:\Users\Darren>
04-02-2015 1:02 PM
Can you try a different Ethernet cable? Some can be dodgy at 1gb/s. Alternatively do you have a laptop or other machine that can test the same cable?
(I'm assuming wifi internet speeds are OK)
04-02-2015 1:03 PM
Whats the speed like loading the routers own web pages?
Is it possible to try another ethernet cable, I assume you'll need to move the PC to the router if it's a shorter cable, you must have a spare from the Plusnet router -- use the one with the red plug, that's a gigabit cable the other is just fast ethernet.
If that's ok then suspect the new ethernet cable
You could also test a direct connection from your PC to the BT modem using the new ethernet cable, taking the TP-Link out of the equation.
For the PC setting to do this,see: http://community.plus.net/library/broadband/fibre-help-how-to-set-up-a-pppoe-dialler-in-vistawindows...
If that's ok then suspect the TP-Link router. Double check by replacing the TP-Link with the old Plusnet router.
04-02-2015 1:34 PM
Thanks again for taking the time to help.
