Pro add on on fibre
parisbeach
Pro add on on fibre
I am still paying for pro add on with fibre should i continue this or stop it. as speeds aint that great as it is
1 REPLY 1
Fixes: 167
Re: Pro add on on fibre
Give it a try without, Pro doesn't really make a huge difference on our current products so you shouldn't find it causes you any issues if you turn it off.
 Chris Parr
 Plusnet Staff
