Pro Add-on
- Pro Add-on
Re: Pro Add-on
24-01-2016 8:34 PM
It's the other protocols that get lifted to the same priority as web browsing that is the problem.
There's no overall rate limits on the current Unlimited products like there used to be on the old ones - we get line speed all day, every day so the priorities only have any effect when the individual user's line is fully loaded. For the vast majority of users any effect the Pro add-on has is detrimental.
Re: Pro Add-on
24-01-2016 8:48 PM
Re: Pro Add-on
24-01-2016 8:55 PM
Re: Pro Add-on
27-01-2016 2:31 PM
So I pay £5 extra and lose 4Mbps, thanks.
Would it worth resetting my line speed, it is currently set to 78Mbps, but could something be stuck somewhere?
My top speed has decreased but my 0-60 time has decreased, is the best way I can describe this, as I do feel that things are generally more responsive due to the higher priority, but I want both!
Re: Pro Add-on
27-01-2016 3:24 PM
Quote from: spoon DON'T
If you are on an unlimited product it's of minimal or no benefit and a waste of money. In some circumstances it's affects are detrimental.
There's a number of topics on here discussing this.
What part of that did you not understand?
It's a con and could be called a lot of other things that would get me in trouble with the moderators.
Why do you think you need the Pro add-on given that one thing it has never been described as doing is increasing your speed?
Re: Pro Add-on
27-01-2016 3:54 PM
Re: Pro Add-on
27-01-2016 5:04 PM
Re: Pro Add-on
27-01-2016 5:09 PM
The add-on has two affects:
1. If you are running protocols that are normally lower priority at the same time they will be given higher priority and so may slow down other normally higher priority tasks.
2. You will be £5 per month worse off.
Before Plusnet introduced Unlimited accounts they had less capacity and peak time contention was far more frequent. There were also rate limits on some protocols at different times of the day. The Pro add-on was introduced then and did make a difference. They should never have made it available for Unlimited users.
Re: Pro Add-on
27-01-2016 5:10 PM
Hoping that when I get migrated on to the 'new network' that will help.
Re: Pro Add-on
27-01-2016 5:12 PM
Quote from: spoon You are misunderstanding how it works. Unless Plusnet's network is running hot (and we have not seen that recently) it only changes the priority of the stuff on your individual line. So if you are not maxing out your line, whether the traffic is top or bottom priority will not a jot of difference. The latency is only affected by the physical length of the line, the routers etc it goes through and the speed of the connection. None of those can be changed by the add on.
The QoS markings are end to end. It is set within the IP header and any device that performs QoS will use that information.
speedguide.net are showing what marking they receive in the packets I send them, which is set by PN, as any marking that I apply gets re-marked. The default in Windows is no marking unless one specifically alters the QoS marking of traffic which can be done in Windows, but as I explained, I am an 'untrusted' source so PN strip the marking's if any and use DPI to mark traffic according to their policy, this is for both outgoing and incoming traffic.
Re: Pro Add-on
27-01-2016 5:57 PM
Link
Re: Pro Add-on
27-01-2016 6:10 PM
If you're concerned about not paying enough for your broadband, the Pro add-on is a way to pay Plusnet £5 a month more.
Re: Pro Add-on
27-01-2016 8:34 PM
The only people who should consider this product are those on Essentials, Extra, Value, Pro, Premium, Essential, Premier, Broadband Plus, BBYW (but not BBYW Pro). For them it makes perfect sense and works as expected.
Re: Pro Add-on
29-01-2016 10:51 PM
Providing your own bandwidth is not saturated and PlusNets network is running as normal, Pro will make no difference.
The only time Pro does help.
1) If say you work from home over a VPN, and other people on your line have saturated your line with games or VoIP, it will help your VPN.
2) If there is a problem in PlusNets or general internet, say there is a 9/11 event, or say major internet systems are down, Email/VPN/basic web browsing is already a priority in this situation, however if your Pro I read VPN priority even more.
And it's true PlusNet can't control QOS on upstream, so your router should have QOS enabled on upstream where possible.
Re: Pro Add-on
30-01-2016 12:37 AM
If I mark the traffic in Windows to CS7, that is getting re-marked to CS5. PN are marking upstream traffic, if that isn't evidence of that, I don't know what is.
The point is, is that the QoS marking is kept all the way to the end unless ignored, wiped or re-marked, and if congestion occurs anywhere in that link and a layer 3 aware device is configured to look at the QoS marking, a packet marked CS5 will have a higher priority than anything marked below that, so the marking is useful throughout the packets travel.
