Pro Add-on Query
Malachor
Pro Add-on Query
Hi All,
We have the unlimited fibre package (~39mb) and noticed that, during peak times (5pm-10pm), our streaming of movies via Netflix/Prime etc. is extremely slow compared to earlier/later in the day.  Having read your traffic management/speed guides and related articles, I opted for the pro add-on to help prioritise our connection and hopefully speed things up.  I only added the package yesterday but had confirmation that it was active and things should improve, but I can confirm streaming is still extremely slow.
For info:
Streaming devices physically connected via Ethernet cable
BT Speed Test shows correct download speed of 36~40mb.
Would someone be able to clarify if, when this package is active, it should help with streaming issues? If not, I'll cancel it and save myself £5 a month if it's not going to help.
Many thanks
Mal.
Fixes: 62
Re: Pro Add-on Query
no it won't
Starmans
Is the streaming via Wifi?
ricke17
I binned the add on as it made no difference with my streaming
Fibre Broadband 80/20, Netgear D7000
rongtw
Fixes: 12
The pro add on will only make a difference on ADSL connections not Fibre
Fixes: 10
Not correct!
Pro doesn't make a difference on any of the Unlimited products* as they give line speed all day on all protocols.
It WILL make a difference to things like Plusnet Extra Fibre.
* One exception to this is the version of Unlimited sold during 2009
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
leader
Unless under  abnormal load conditions (plan B & C) ?
