Pro Add On
mactell
Pro Add On
So I've just seen PN offer a 'Pro Add on' does this actually make any improvement to the connection or speed? Thoughts....?
Upgrade your service for a prioritised connection, perfect for when you’re working from home. When you’ve got a busy household all online at the same time, Plusnet Pro prioritises key activities such as VPN access, software updates and FTP access so that you can get on with important work. Subject to a 1 month rolling contract.
Aspiring Hero
Fixes: 70
Re: Pro Add On
It won't increase your speed, it will just give priority connections to the services quoted at the expense of any other running download/upload activities.
mactell
Re: Pro Add On
Thanks @Baldrick1 (Love the name by the way). It sounds like I may as well just setup QOS on my router then lol.
Aspiring Hero
Fixes: 70
Re: Pro Add On
Yes.
