Pro Add On charge
firebird1000
Pro Add On charge
hi here now that plus.net have dropped there  traffic prioritisation on the /28/6/17  29/06/17 do i still have to pay £5.00 for the pro add on our will this be another way to get more money /
firebird1000
Re: Pro Add On charge
it seems no one from plus net wants to say any thing are well so i have to keep paying i hope not  i dont think prioritisation has been fully  removed
Fixes: 43
If you want to retain the Pro Add-on I expect it remains chargeable. However you have the option of cancelling it to save the £5pm.
David
Fixes: 233
Sorry about my late response.
As has advised the Pro Addon will remain chargeable. Now that traffic prioritisation is all but gone, the Pro Addon will essentially provide you with a similar service. Alternatively, if you'd like to cancel it you can do that here
Anoush
rongtw
Fixes: 11
@Gandalf   a question ?  if a customer is having problems and can prove its because of traffic prioritisation  , and the way to fix this is the Pro add on .
Would PN still charge £5 a month to fix his connection ?
Fixes: 233
So far we've had no reports that the removal of traffic prioritisation is actually causing an issue.
However, if it's proven that the removal is having a negative impact on a customer's connection, then as a gesture of goodwill we will apply this free of charge for 12 months. It'll be assessed on a case by case basis.
firebird1000
so if i remove it and find problems how do i proof it Huh? will try to see when i remove it before next billing time there agian proof and how do i do that ?Huh
Fixes: 8
A subsidiary question.  Now that Plusnet has removed the TP service on the grounds that it no longer needed, will Plusnet be reviewing all of the customers currently paying for Pro Add On and offering the option to get a refund from the time that the Pro Add On was agrred to be uneccessary?
M
Fixes: 43
When you originally added it, what prompted you to do this? Were P2P downloads taking longer than you desired because others in the household were taking excessive bandwidth on things like streaming?
Can you demonstrate the situation now, then repeat after removal?
Anoush provided a link for cancelling the Pro Add-on https://www.plus.net/AddOns.html. Cancellation should take effect immediately with a pro-rated refund on your next bill. This shouldn't matter if staff provide the Pro Add-on for free but if you want to turn it on again yourself wait until the refund billing date is past to avoid confusing the billing system.
David
firebird1000
hi why do you think i use p2p downloads  is this an auto response to say i do as you can check on my use the only p2p was my son on steam network and not  only  like 1gb or 2gb so that would not be the prob / and i do a lot of streaming but my son does a lot more gaming so forget p2p Huh?Huh
Fixes: 16
No-one thought you used P2P.
You probably never actually needed the Pro add-on previously with Plusnet's default traffic prioritisation.
Fixes: 43
I've no idea whether or not you use P2P. As a fellow customer I have no access whatsoever to your account information - only staff have that and I am not staff.
The only reason I mentioned P2P is that generally it is seen as a lower priority protocol compared with streaming and browsing and the traffic management previously in place reflected that. The Pro Add-on made the priority of all of those equal which suited they way some households used their connection.
Based on what you described I don't think that applied in your case.
David
