Predicted speed range from stats
jmac80
Hello all
I know i cant get exact speed predictions for fibre from adsl stats but i'm just wondering what to roughly expect so here's the info on my line/exchange..
Exchange is NSULL and it's due to get fibre in the next couple of months.
Every house in our village is EO lines and i believe they will be installing cabinets near the exchange..
My line must be about 1200m to the exchange and probably 800m to where i believe they will be putting the cabinet (well i seen them doing a lot of work there but no cabinet installed yet)
At the moment the max adsl we get here is 8mb and my vigor 130 modem has the following stats:
Down speed 8128000
Up speed 448000
SNR Margin 15
Loop Att. 17
No matter what router i have had over the last 10 years i have always synced at the full 8mb.
The lines in my village are very good i believe...
Any rough estimates on what sort of speed i may achieve maybe if its close to your own stats while on adsl before going onto fibre.?
can anyone from plusnet also find out more about predicted cabinet locations or dates etc?
Fixes: 62
Re: Predicted speed range from stats
I am about 1100m from the cab
Connection speed (kbps): 45796 / 9028
ADSL stats are completely irrelevant
jmac80
Thanks, Does the Line attenuation not come into play? or does it change when you get fibre?
That's a good speed you have there and i have seen a few others post similar but then i wonder why all the fibre line length/speed graphs so such rubbish speeds, for example your line would be about 25mb according to the graphs.
Fixes: 62
Compare the estimate when I ordered it to that now a few more users have taken it up
jmac80
How come you adsl max predicted speeds are so rubbish?
Fixes: 62
because I am a long way from the exchange
jmac80
But currently i must be about the same maybe even 100m more and i get the full 8mb sync, Without fail i sync at 8128kbps
mav:quote
SpendLessTime
Aspiring Hero
Fixes: 67
@mac80
Oldjim is 1100m from the cabinet, the exchange is much further away. You are 1200m from the exchange. For ADSL it is distance to the exchange, for FTTC to the cabinet.
jmac80
Ah yes sorry i missed that.
mav:quote
