Predicted speed range from stats
- Re: Predicted speed range from stats
10-01-2016 7:06 PM
Hello all
I know i cant get exact speed predictions for fibre from adsl stats but i'm just wondering what to roughly expect so here's the info on my line/exchange..
Exchange is NSULL and it's due to get fibre in the next couple of months.
Every house in our village is EO lines and i believe they will be installing cabinets near the exchange..
My line must be about 1200m to the exchange and probably 800m to where i believe they will be putting the cabinet (well i seen them doing a lot of work there but no cabinet installed yet)
At the moment the max adsl we get here is 8mb and my vigor 130 modem has the following stats:
Down speed 8128000
Up speed 448000
SNR Margin 15
Loop Att. 17
No matter what router i have had over the last 10 years i have always synced at the full 8mb.
The lines in my village are very good i believe...
Any rough estimates on what sort of speed i may achieve maybe if its close to your own stats while on adsl before going onto fibre.?
can anyone from plusnet also find out more about predicted cabinet locations or dates etc?
Down speed 8128000
Up speed 448000
SNR Margin 15
Loop Att. 17
Message 1 of 9
(1,276 Views)
8 REPLIES 8
10-01-2016 7:09 PM
I am about 1100m from the cab
Connection speed (kbps): 45796 / 9028
ADSL stats are completely irrelevant
Message 2 of 9
(739 Views)
10-01-2016 7:22 PM
Thanks, Does the Line attenuation not come into play? or does it change when you get fibre?
That's a good speed you have there and i have seen a few others post similar but then i wonder why all the fibre line length/speed graphs so such rubbish speeds, for example your line would be about 25mb according to the graphs.
Message 3 of 9
(739 Views)
10-01-2016 7:44 PM
Compare the estimate when I ordered it to that now a few more users have taken it up
Message 4 of 9
(739 Views)
10-01-2016 8:07 PM
How come you adsl max predicted speeds are so rubbish?
Message 5 of 9
(739 Views)
10-01-2016 8:16 PM
because I am a long way from the exchange
Message 6 of 9
(739 Views)
10-01-2016 8:26 PM
But currently i must be about the same maybe even 100m more and i get the full 8mb sync, Without fail i sync at 8128kbps
mav:quote
mav:quote
Message 7 of 9
(739 Views)
10-01-2016 8:53 PM
@mac80
Oldjim is 1100m from the cabinet, the exchange is much further away. You are 1200m from the exchange. For ADSL it is distance to the exchange, for FTTC to the cabinet.
Message 8 of 9
(739 Views)
10-01-2016 8:59 PM
Ah yes sorry i missed that.
mav:quote
mav:quote
Message 9 of 9
(739 Views)
