Power cut = better upload speed?
- Power cut = better upload speed?
10-11-2016 9:45 AM
I thought disconnects lower speed though? Snr is 6.0/6.0 is this bad?
We had 3 Power cuts in a row and i still have 6.5 mb upload lol, what is this sorcery! If bt say all my line can handle is 5.5 mb how can a power cut give me more speed? I bet if I restart my router it will go back down again
Re: Power cut = better upload speed?
10-11-2016 11:03 AM
I believe that an event such as a power cut, which affects a large number of customers, is ignored by DLM. You presumably were re-connected after the cut at a time when line conditions were rather better than the last time you connected, resulting in a higher speed.
10-11-2016 12:15 PM
I dont actually think DLM works for me lol, i had my connection on for like 15 days straight and no increase what so ever
11-11-2016 1:30 PM
Fibre DLM is not a quick thing to make changes, it also helps if there is the occasional resync.
11-11-2016 4:03 PM
What can i do to try and help DLM? and hopefully try and increase my speed overtime?
11-11-2016 4:12 PM
11-11-2016 4:25 PM
