Potentially high SNR
moansalot
Hi - Can I kindly request that a CS rep take a look at my line/  Profile and perhaps run a GEA test
Many in this forum would no doubt kill for my current 66mb d/l and 18-19mb upload  ( speeds as per Fast.net ) so apologies to those struggling with speeds .
My SNR  appears to be higher than historic figures  - Hub stats ( taken a few min ago ) attached  ( BT Business hub)  -  it was suggested that my Line might be banded ! ( previous achievable line speeds have been circa 72-75mb d/l ( admittedly some time ago ) and SNR figure had been stable at 6.0 for d/l  it's now showing as 8.8 !
Many thanks
8 REPLIES 8
Fixes: 1,430
Re: Potentially high SNR
Thanks for your post @moansalot
A throughput of 66mbps is about right for your sync speed of 74mbps, because there's retransmission high enabled on your line, which takes a chunk of your speed unfortunately, bringing the line speed down to 70mbps.
Your line's banded though at 74mbps so I've arranged for this to be removed within the next 3 working days.
Let us know how it goes. I've attached our testing below as well:
GEA Test Detail
Circuit ID NA Service ID [redacted]
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 70.8 Mbps
Upstream Speed 20.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Cross Talk Not Detected
Estimated Line Length In Metres 425.0
Upstream Rate Assessment Very Good
Downstream Rate Assessment Good
Interference Pattern Regular Interference Observed Daily
Interference Duration Longest Occurrence ;00:00to23:45
Interference Location Customer Premise
Interference Observed In Days 14
Technology VDSL
Current 15Min Bin Retrains 0
Last 15Min Bin Retrains 0
DP Type External
Profile Name 0.128M-74M Downstream, Retransmission High - 0.128M-20M Upstream, Error Protection Off
Time Stamp 2021-05-22T14:00:00
Parameters MIN MAX AVG
Down Stream Line Rate 73.9 Mbps 73.9 Mbps 73.9 Mbps
Up Stream Line Rate 19.9 Mbps 19.9 Mbps 19.9 Mbps
Up Time 3.0 Sec 900.0 Sec 888.8 Sec
Retrains 0.0 1.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2021-06-04T12:34:29Z 2021-06-04T12:49:29Z
Ingress Code Violation 0 0
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
moansalot
@Gandalf -  Thanks for the prompt reply  - I'll keep a check on this over the next few days with fingers crossed -
For info note on the GEA test results you posted there is a mention of regular interference detected / customer premise !
I have only recieved one drop of service - green light on hub (that I have noticed which was yesterday morning)  otherwise and all testing done with Ethernet direct to the hub ( which is permamently connected to the test socket and has been for sometime )  - so not sure where the regular interference that was detected  is coming from  - mmm
Thanks Paul
Fixes: 1,430
No problem Paul, I'd take the interference detected with a pinch of salt as it may not be affecting your service.
Fixes: 94
Hi Paul,
It could be coming from a multitude of sources!!
If there is local interference you are only going to identify that by micro monitoring your router.  If it is the Plusnet Hub One (which is a BT Hub 5A) then the appropriate version of Router stats (link below) might be useful.
moansalot
@Townman @Gandalf
Many thanks for the info / assistance - looks like the changes made by Gandalf have kicked in  d/l SNR is now 6.1  - which seens to have added a couple of mb to my d/l speeds which is always useful  -  will keep monotoring my stats  -  will let you know if any problems arise.
Will lookinto that Router stats software you mentioned @Townman  -  FYI  my router is not the Plusnet Hub One  - it is a BT 6 - type A  Business hub  - which fingers crossed has worked well
Fixes: 1,430
Thanks for getting back to us @moansalot
Awesome, I'm glad to see your speed has improved now.
Let us know if there are further issues or anything else you'd need help with.
P.S. I hope neither you nor @Townman mind but I've asked the mods to move the fix to me. Smiley
moansalot
Update
D/l as per Fast.com   d/l now 73mb up 20mb  and snr is now 7.1 d/l
finally backto original speeds ( that i signed up /pay for ) after almost a year in the low 60's d/l
Cheers
Fixes: 1,430
Nice! Cheers for the update @moansalot
