Potential Speed - Migrating Customer
sjptd
Re: Potential Speed - Migrating Customer
 Has anyone ever seen where the sync speed is higher than the estimated (rather than the other way around which you see a lot of)?
Lots of answers to the OP, but not specifically to that.  Yes: I have an estimate of 45-66 and had a speed just under 70 on BT.
Currently lower (58) as I have just moved to Plusnet and think there was a DLM reset or ? on a max data rate of 70.  I hope it will increase in a few days.  (I know there is still argument about this, but evidence does seem to support the settling in theory)
LaurenB
Fixes: 131
Hi @sjptd, as @Jubby mentioned, based on experience it is better to wait until after the stabilisation period before we start raising it.
Let us know how it is in a few days.
 Lauren Barry
Xup
My BT's max speed available on their checker is 48.9.
Here is what I get 12 days in on a new PlusNet connection.( I have vectoring on my line)
SammyM
Fixes: 96
Hello @Xup,
Thanks for getting back to us.
Looking at your line we can see that it is performing above estimates provided by our supplier. The speeds our suppliers provide us with are estimated and can change depending on a number of factors. As its stands everything is testing OK and let us know if you have any problems.
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 69.3 Mbps
Upstream Speed 7.9 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Estimated Line Length In Metres 768.9
Upstream Rate Assessment Reasonable
Interference Pattern Regular Interference Observed Daily
Interference Duration Longest Occurrence From 23:45 to 03:30
Interference Location Customer Premise
Interference Observed In Days 10
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Profile Name 0.128M-55M Downstream 3dB, Retransmission High - 0.128M-10M Upstream, Error Protection Off
Time Stamp 2018-08-16T15:30:00
Parameters MIN MAX AVG
Down Stream Line Rate 53.2 Mbps 73.0 Mbps 65.0 Mbps
Up Stream Line Rate 7.8 Mbps 8.2 Mbps 8.0 Mbps
Up Time 524.0 Sec 900.0 Sec 898.7 Sec
Retrains 0.0 4.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2018-08-29T13:53:16Z 2018-08-29T14:08:16Z
Ingress Code Violation 0 0
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
 Sammy M - Sheffield Team
RealAleMadrid
Aspiring Hero
Fixes: 59
@SammyM  I think Xup was just showing us how lucky he is to have a very good sync speed way above the checker estimate, probably because of vectoring being enabled. It was his first post in this thread.
Xup
^^^ Yes just showing that you can get more than the BT checker shows.
@SammyM  since you have done a GEA test  :), Can I ask  why the test shows I am on a 10/55 product profile ….when I am paying for a 20/80 service !.
Can this be sorted please :).
TheMightyAJ
Fixes: 126
Hi @Xup, I've taken a look into your account today and raised a ticket regarding this, which can be viewed here.
 Alex H
Xup
@TheMightyAJ  Thanks for that, to be fair here I'm not being restricted to those speeds (10/55)
I'm receiving
feeps
@Xup Wow at that speed for the distance! Your Attenuation is higher than mine at 22.3 too!
How do you know you have vectoring? Is it something that is automatically applied?
But yeah, managed 62mb with Sky, so happy with anything 55mb+ stable for now Smiley
@LaurenB seeing as you did a GEA test, can I see the results please?
Thanks!
Geek, Photographer, Gamer.
RealAleMadrid
Aspiring Hero
Fixes: 59
@Xup I must admit I missed that profile info on your GEA test. This is an issue I have repeatedly brought up on this forum but it has been totally ignored by PlusNet staff.  You are obviously not on a 55Mbps downstream profile. Have a look at the time stamp below the profile name row. It is out of date .. the 16th of August is nearly 2 weeks ago and your sync speed has changed since then and your line is not banded at that speed. I would be interested to know what TheMightyAJ put in the ticket he raised. I would guess nothing sensible or relevant to the situation.Wink
Xup
Not 100% on this but as far as I know.
You need to be on an Huawei cab.
You need to be on a BDUK funded cab. (I'm in a rural area, 4k from the exchange 800 from the cab)
If you can telnet into your router use the command
"adsl info --vectoring" ...............without the ""
You are looking for a vectoring state of 1 to be fully working.
Pic
Smiley
feeps
Guess not! (Changed from 192.168.1.254 to 192.168.0.1) - Using a BT HH 6A.
Xup
@RealAleMadrid
Good spot, that date was a day before I ported over to PlusNet on the17th, from BT on a 55/10 product.
feeps
Today's update after an automated re-sync at the same time as previous re-sync, 8:20am. (When on Sky, was around 1am)
0 Days, 0 Hours 8 Minutes 40 Seconds
6.64 Mbps / 52.79 Mbps
6642 / 53853
6.2 dB / 4.1 dB
G_993_2_ANNEX_B
Getting there, next step in 2 days time should be 3db down hopefully. I wonder why the upload SNR hasn't changed, dropped from 7.1 to 6.6 on a 6db SNR though. Is it handled separately by the DLSM at a later point if at all? As in if it hasn't done it by now, it won't do it at all?
Need to read more into G.INP / Vectoring that @Xup has but not sure how to tell if it has been applied to the line, is there any way to force it?
Regards,
Aaron
Xup
@feeps, You cant really force it as it has to be available in the cabinet you are connected to, seems only BDUK funded cabs have it to increase the people who can reach the superfast target on long lines.
You can still improve your connection and increase your attainable speeds with little tweaks.
I gained 4Mb by changing from the BT smart hub to the Billion 8800NL. (the white R1 model)
Gained just over 1Mb by swapping out the DSL cable for one of the Tandy higher quality ones.(keep it short as possible
and away from power cables)
Link to Tandy cable.
https://www.tandyonline.com/electronics/telecoms-dsl/high-speed-rj11-dsl-cable-0-5m.html
