Possible stuck profile
- Possible stuck profile
28-11-2020 3:27 PM - edited 28-11-2020 3:30 PM
I have experienced gradully reducing speeds on my Plusnet service over teh past 18 months. Coudl someone take a look for me please?
My stats are:-
Actual Rate down: 22399
Attainable rate down: 30234 (used to be closer to 40 Mb/s)
Path Fast
SNR Margin 15 dB
CRC & ES rate stays at zero
I wonder if the line has become banded as the SNR margin is way too high - Plusnet can this be changed please?
BT Line checker says:-
Featured Products | Downstream Line Rate(Mbps) | Upstream Line Rate (Mbps) | Downstream Handback Threshold(Mbps) |
WBC FTTC Availability Date | WBC SOGEA Availability Date | Left in Jumper | ||
High | Low | High | Low | |||||
VDSL Range A (Clean) ![]() |
41.1 | 27.4 | 7.7 | 6 | 22.4 | Available | Available | -- |
VDSL Range B (Impacted) ![]() |
40 | 22.4 | 7.6 | 5.1 | 18 | Available | Available | -- |
Featured Products | Downstream Line Rate(Mbps) | Upstream Line Rate (Mbps) | Downstream Range (Mbps) | Availability Date | FTTP Install Process |
WBC FTTP | Upto 1000 | Upto 220 | -- | Available | 1 Stage |
ADSL Products | Downstream Line Rate (Mbps) | Upstream Line Rate (Mbps) | Downstream Range(Mbps) | ADSL Availability Date | WBC SOADSL Availability Date | Left in Jumper |
WBC ADSL 2+ | Up to 8.5 | -- | 5.5 to 11 | Available | Available | -- |
WBC ADSL2+ Annex M | Up to 8.5 | Up to 1 | 5.5 to 11 | Available | Available | -- |
ADSL Max | Up to 6 | -- | 5 to 8 | Available | Available | -- |
WBC Fixed Rate | 2 | -- | -- | Available | Available | -- |
Fixed Rate | 2 | -- | -- | Available | -- | -- |
Observed Speeds | VDSL |
Max Observed Downstream Speed | 22.39 |
Max Observed Upstream Speed | 7.48 |
Observed Date | 2020-11-28 |
Other Offerings | Availability Date |
VDSL Multicast | Available |
ADSL Multicast | Available |
Premise Environment | Status |
Bridge Tap | N |
VRI | N |
NTE FacePlate | P |
Last Test Date | 21-11-2020 |
Exchange Product Restrictions | Status |
FTTP Priority Exchange | N |
WLR Withdrawal | N |
SOADSL Restriction | Y |
Re: Possible stuck profile
29-11-2020 3:10 PM
Together with our network partners at Openreach we will try to provide you with the best speeds possible. If you feel this is not the case, please raise your speed fault online at faults.plus.net
30-11-2020 9:04 PM
Thanks - have riased a ticket now
02-12-2020 8:18 PM
Not had any acknowledgement of the ticket - no opportunity to specify the fault - just a generic we'll look into things message. No fault refernece number, and no abaility to track the fault......
What do I do next?
03-12-2020 3:34 PM - edited 03-12-2020 3:36 PM
Hi @ccarmock, thanks for getting back to us. I'm afraid I can't see a raised fault on your account when checking. Not to worry however, as when running a test over your connection I can see we're picking up a line fault which very well could be behind the speed issues as of recent.
Test Outcome |
Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0000 |
Description | GEA service test completed and no fault found . |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 21.3 Mbps |
Upstream Speed | 7.5 Mbps |
Appointment Required | N |
Fault Report Advised | N |
NTE Power Status | PowerOn |
Voice Line Test Result | Voice fault suspected - contact Voice CP to progress copper issue |
Radio Frequency Ingress | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Cross Talk | Not Detected |
Estimated Line Length In Metres | 1107.9 |
Upstream Rate Assessment | Very Good |
Downstream Rate Assessment | Reasonable |
Interference Pattern | Not Detected |
Service Impact | No Impact Observed |
Home Wiring Problem | Not Detected |
Technology | VDSL |
Current 15Min Bin Retrains | 0 |
Last 15Min Bin Retrains | 0 |
DP Type | External |
Profile Name | 0.128M-22.4M Downstream, Retransmission High - 0.128M-10M Upstream, Error Protection Off |
Time Stamp | 2020-11-20T15:30:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 22.3 Mbps | 22.3 Mbps | 22.3 Mbps |
Up Stream Line Rate | 7.4 Mbps | 7.6 Mbps | 7.5 Mbps |
Up Time | 860.0 Sec | 900.0 Sec | 899.9 Sec |
Retrains | 0.0 | 1.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2020-12-03T15:03:31Z | 2020-12-03T15:18:31Z |
Ingress Code Violation | 4 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
As the phone line isn't with us I'm unable to test further and get this raised our side however I'd advise if you give your phone provider a call and ask them to test the line they should pick up the external fault we are getting hints of when looking at the broadband and hopefully they should be ale to raise this externally for you.
Let us know how it goes and should you still have speed problems after the line fault has been clear let us know and we'll happily investigate further.
04-12-2020 2:38 PM
THank you Ben - I'll call BT re the possible landline fault.
04-12-2020 5:32 PM
@ccarmock The obvious fault that Plusnet will have to sort out is that your line is capped on a banded profile of 22.4 Mbps. Fixing any phone line fault will probably not change this, a DLM reset will be required.
08-12-2020 9:36 PM
Yes I think you are right re banding.
BT have tested the voice path on the line and said no fault is found....
