Possible line fault
FIXED- Subscribe to RSS Feed
- Possible line fault
04-07-2016 3:14 PM
Hi
I raised a ticked on satursay regarding a line fault, do any of you know what is happening?
I have check the status and all it says is its in the hands of the faults team.
Attached is a report from BT Wholesale.
Regards
Andy
Fixed! Go to the fix.
Re: Possible line fault
04-07-2016 3:23 PM
The speed you are getting on your downstream is *exactly* what I'd expect to see on the product you are on. It will show as red, but that's because the wholesale product allows up to 80Mb/s speeds, but on the service you are on we currently restrict this to 40Mb/s. Regardless of that, your estimates start at 40Mb/s too, so the speeds you are getting down are not considered a fault at all.
The upload is slightly lower than it should be, so our faults team will investigate that, but the downstream is not an issue at all.
04-07-2016 3:29 PM
Thanks for getting back Chris.
At least its not bad news!
06-07-2016 11:17 AM
Hi Chris
Any news on this "possible fault" as it was reported saturday? and i have not heard anything?
06-07-2016 11:36 AM
BT Speedtest results:
Down: 38050
Up: 9640
Sync speeds:
Downstream Speed | 41.9 Mbps |
Upstream Speed | 12.5 Mbps |
As per my previous response, I don't see any huge issues. The message you've highlighted on the screenshot is most likely due to the speed cap on your account. The speedtest results recorded above show no issue.
06-07-2016 11:38 AM
Thanks Chris I'll close it.
