Possible DLM resetted as my line are now banded
- Possible DLM resetted as my line are now banded
20-08-2018 12:29 PM
Just has my email alert to say my modem resync has happen today at 11:34am after 3 days stable connected.
Before resync: Mode VDSL2 Traffic Type PTM Status Up Link Power State L0 Downstream Upstream Line Coding (Trellis) On On SNR Margin (dB) 6.4 15.1 Attenuation (dB) 11.9 0.0 Output Power (dBm) 12.5 0.9 Attainable Rate (Kbps) 79145 27111 Rate (Kbps) 78389 19999 Throughput speed: 74Mbps 19Mbps
After resync:
Mode VDSL2 Traffic Type PTM Status Up Link Power State L0 Downstream Upstream Line Coding (Trellis) On On SNR Margin (dB) 7.3 7.6 Attenuation (dB) 12.0 0.0 Output Power (dBm) 12.5 1.3 Attainable Rate (Kbps) 79168 17694 Rate (Kbps) 74022 17745 Throughput speed: 50Mbps 16Mbps
I want to know why my throughput are very poor via ethernet and don't know why it capped at 50/16 from 74/19
http://www.speedtest.net/result/7566551392.png
1. Best Effort Test: -provides background information.
Download Speed | |
50.84 Mbps |
0 Mbps | 71.57 Mbps Max Achievable Speed |
Download speedachieved during the test was - 50.84 Mbps For your connection, the acceptable range of speedsis 40 Mbps-71.57 Mbps . Additional Information: IP Profile for your line is - 71.57 Mbps |
Upload Speed | |
21.5 Mbps |
0 Mbps | 20 Mbps Max Achievable Speed |
Upload speed achieved during the test was - 21.5Mbps Additional Information: Upstream Rate IP profile on your line is - 20 Mbps |
Re: Possible DLM resetted as my line are now banded
20-08-2018 1:59 PM
I managed to force DLM to removed banded on my line via telnet to force it to removed it off. It's has successfully removed it off.
(leave my line alone DLM)
Mode VDSL2 Traffic Type PTM Status Up Link Power State L0 Downstream Upstream Line Coding (Trellis) On On SNR Margin (dB) 6.4 15.1 Attenuation (dB) 12.0 0.0 Output Power (dBm) 12.5 0.9 Attainable Rate (Kbps) 79145 26598 Rate (Kbps) 78343 19999 Throughput speed: 73Mbps 18Mbps
http://www.speedtest.net/result/7566780518.png
For your connection, the acceptable range of speedsis 40 Mbps-75.75 Mbps .
IP Profile for your line is - 75.75 Mbps
20-08-2018 2:42 PM
Could PN please send me GEA Test and connection log history to my ticket please thanks.
20-08-2018 3:10 PM
I have ran some checks on your line today. Looking at the GEA, the speed is looking fine but it is showing an error on the line. Please can you try connecting to the test socket for me to rule out any internal issues. If you are connected to the test socket please let me know.
Test Outcome | Fail |
Test Outcome Code | GTC_FTTC_SERVICE_1625 |
Description | Impairment in copper joint detected most likely in local network. Please continue to submit a trouble report |
Main Fault Location | CE |
Sync Status | In Sync |
Downstream Speed | 78.3 Mbps |
Upstream Speed | 20.0 Mbps |
Appointment Required | N |
Fault Report Advised | Y |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Bridge Tap | Not Detected |
Radio Frequency Ingress | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Cross Talk | Not Detected |
Estimated Line Length In Metres | 262.7 |
Upstream Rate Assessment | Very Good |
Downstream Rate Assessment | Very Good |
Home Wiring Problem | Not Detected |
Downstream Policing Discard Rate | 0.0 |
Customer Traffic Level | Upstream and Downstream Traffic Detected |
Technology | VDSL |
Profile Name | 0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off |
Time Stamp | 2018-08-07T15:15:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 10.0 Mbps | 78.8 Mbps | 77.9 Mbps |
Up Stream Line Rate | 9.9 Mbps | 19.9 Mbps | 19.8 Mbps |
Up Time | 0.0 Sec | 900.0 Sec | 886.5 Sec |
Retrains | 0.0 | 1.0 | 0.0 |
20-08-2018 3:20 PM - edited 20-08-2018 3:33 PM
@deank there is no errors on the line (downstream on the ES & SES)
Since Link time = 1 hours 32 min 33 sec
FEC: 30
CRC: 0
ES: 0
SES: 0
UAS: 0
LOS: 0
LOF: 0
LOM: 0
PN why is Estimated Line Length In Metres has changed below:
Before:
Estimated Line Length In Metres | 243.6 |
Now:
20-08-2018 3:39 PM
Hi @goldenfibre
There is an error showing in the GEA above " Impairment in copper joint detected most likely in local network. Please continue to submit a trouble report ". This is most likely an external issue, however, we recommend getting it in the test socket just to rule out any internal issues.
You can find more information on how to do this here.
20-08-2018 3:42 PM - edited 20-08-2018 4:05 PM
@deank nothing to do with my master socket. As it never been changed since. Must be exchange or cabinet faulty.
20-08-2018 3:58 PM - edited 20-08-2018 4:11 PM
@deank will plug into test socket in about few minutes later. Can you please run another GEA Test in half an hour.
Updated: plugged into test socket as DSL failure to getting connecting from cabinet. DSL flashing continue.
It's a fault in the test socket now.
20-08-2018 4:24 PM
Hi @goldenfibre
Which kind of cable are you using there? You will need to attach an ADSL filter to the socket, and plug the DSL cable into the filter. If that is a third party DSL cable you have attached to the socket, do you have an alternate one that you could try just to rule that out?
20-08-2018 4:52 PM - edited 20-08-2018 4:55 PM
@deank I have been to the loft try to find filter to plug into test socket, found it and it now plugged into test socket and dsl light now steady solid on. You can now run another GEA Test. This is the same cable I am using from this link: https://www.tandyonline.com/electronics/telecoms-dsl/high-speed-rj11-dsl-cable-2m.html See photo enclosed below
20-08-2018 5:03 PM - edited 20-08-2018 5:13 PM
Oh dear me! Retrain 200000 DLM more likely to banded the line overnight
adsl info --stats adsl: ADSL driver and PHY status Status: Showtime Last Retrain Reason: 200000 Last initialization procedure status: 0 Max: Upstream rate = 26642 Kbps, Downstream rate = 80044 Kbps Bearer: 0, Upstream rate = 19999 Kbps, Downstream rate = 77616 Kbps Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps Link Power State: L0 Mode: VDSL2 Annex B VDSL2 Profile: Profile 17a TPS-TC: PTM Mode(0x0) Trellis: U:ON /D:ON Line Status: No Defect Training Status: Showtime Down Up SNR (dB): 6.6 15.1 Attn(dB): 11.9 0.0 Pwr(dBm): 12.4 0.6
For your connection, the acceptable range of speedsis 40 Mbps-75.05 Mbps .
IP Profile for your line is - 75.05 Mbps
20-08-2018 5:18 PM
Hi @goldenfibre,
I wouldn't worry to much about that as it shouldn't restrict your performance. I've ran a further test on your line and the fibre banding is currently at 80Mb as expected.
However, the Impairment in copper joint is still showing, so I have raised this to BT Wholesale for you. We expect a response from them within the next 48 hours. Please let us know if you haven't heard anything by Thursday.
20-08-2018 5:25 PM
@deank Thanks. But what happen if DLM decided to banded on my line overnight, what next step or wait for hear back from BT Wholesale. Please do let me know.
20-08-2018 6:21 PM
21-08-2018 9:26 AM - edited 21-08-2018 9:35 AM
Has the suppliers fixed my fibre broadband yet?
Last night DLM has made a change on my line. Both now enabled on interleave depth at 8/8 INP 47/47 but Bearer 0 are now re-tx high on downstream
IP Profile for your line is - 71.67 Mbps (91.96% to the sync rate 77941Kbps due to re-tx high on downstream)
Connection stats adsl info --stats adsl: ADSL driver and PHY status Status: Showtime Last Retrain Reason: 0 Last initialization procedure status: 0 Max: Upstream rate = 29186 Kbps, Downstream rate = 78717 Kbps Bearer: 0, Upstream rate = 20000 Kbps, Downstream rate = 77941 Kbps Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps Link Power State: L0 Mode: VDSL2 Annex B VDSL2 Profile: Profile 17a TPS-TC: PTM Mode(0x0) Trellis: U:ON /D:ON Line Status: No Defect Training Status: Showtime Down Up SNR (dB): 6.4 11.8 Attn(dB): 11.9 0.0 Pwr(dBm): 12.5 0.9 VDSL2 framing Bearer 0 MSGc: -6 -6 B: 243 97 M: 1 1 T: 0 0 R: 10 8 S: 0.0997 0.1554 L: 20384 5457 D: 8 8 I: 254 106 N: 254 106 Q: 8 8 V: 0 2 RxQueue: 80 39 TxQueue: 20 13 G.INP Framing: 18 18 G.INP lookback: 20 13 RRC bits: 24 24 Bearer 1 MSGc: 186 58 B: 0 0 M: 2 2 T: 2 2 R: 16 16 S: 5.3333 16.0000 L: 48 16 D: 3 1 I: 32 32 N: 32 32 Q: 0 0 V: 0 0 RxQueue: 0 0 TxQueue: 0 0 G.INP Framing: 0 0 G.INP lookback: 0 0 RRC bits: 0 0 Counters Bearer 0 OHF: 0 0 OHFErr: 0 0 RS: 1136622680 1939048 RSCorr: 823 187 RSUnCorr: 0 0 Bearer 1 OHF: 1770458 729016 OHFErr: 0 1 RS: 21244763 2815400 RSCorr: 16 7 RSUnCorr: 0 0 Retransmit Counters rtx_tx: 129482 68 rtx_c: 123 1641 rtx_uc: 0 79134 G.INP Counters LEFTRS: 0 25 minEFTR: 77947 19997 errFreeBits: 33807749 399646965 Bearer 0 HEC: 0 0 OCD: 0 0 LCD: 0 0 Total Cells: 4262480695 0 Data Cells: 32733682 0 Drop Cells: 0 Bit Errors: 0 0 Bearer 1 HEC: 0 0 OCD: 0 0 LCD: 0 0 Total Cells: 0 0 Data Cells: 0 0 Drop Cells: 0 Bit Errors: 0 0 ES: 0 0 SES: 0 0 UAS: 26 26 AS: 28443 Bearer 0 INP: 47.00 47.00 INPRein: 1.00 0.00 delay: 0 0 PER: 0.00 0.00 OR: 0.01 0.01 AgR: 78021.15 20102.08 Bearer 1 INP: 4.00 4.00 INPRein: 4.00 4.00 delay: 3 0 PER: 16.06 16.06 OR: 95.62 31.87 AgR: 95.62 31.87 Bitswap: 1/1 1/1 Total time = 7 hours 54 min 29 sec FEC: 823 187 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 26 26 LOS: 0 0 LOF: 0 0 LOM: 0 0 Latest 15 minutes time = 9 min 29 sec FEC: 2 4 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Previous 15 minutes time = 15 min 0 sec FEC: 6 0 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Latest 1 day time = 7 hours 54 min 29 sec FEC: 823 187 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 26 26 LOS: 0 0 LOF: 0 0 LOM: 0 0 Previous 1 day time = 0 sec FEC: 0 0 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0 Since Link time = 7 hours 54 min 1 sec FEC: 823 187 CRC: 0 0 ES: 0 0 SES: 0 0 UAS: 0 0 LOS: 0 0 LOF: 0 0 LOM: 0 0
For your connection, the acceptable range of speedsis 40 Mbps-71.67 Mbps .
- Telephone number:
- Phone exchange:
- CUCKOO OAK
- Estimated line speed:
- 80Mb (This may vary between 70Mb and 80Mb) - Checked on 2018-01-29 15:15:29
- Current line speed:
- 71.4 Mb
