Port Forwarding on Technicolor TG582n
Wheelspin
I have a git server running in a docker container.   The container publishes port 2222 to the host interface.  I have setup a port forward on the router from 5000->server:2222.  When I try to run:
git clone ssh://git@<external_hostname>:5000/<repo>
I get connection refused.
If I try to connect from the docker host on port 2222 then it works.
This is odd as I already have various port forwards setup to the docker host, namely port 22, 80, 443 and the standard mail ports.  These all work fine.
Wheelspin
Re: Port Forwarding on Technicolor TG582n
I also ran:
 nc -v -z <external_hostname> 5000
and got connection refused too.
I've also tried using a port in the standard range (23 to be exact) and go the same problem.
Fixes: 162
So you already have identical rules set up for the other ports (22, 80 etc) and they are still working fine?
What about if you set up a standard port forward rule to forward 2222 to 2222 (just as a temporary test), does that work?
 Chris Parr
 Plusnet Staff
Wheelspin
Same thing.
Fixes: 181
I'm afraid port forwarding isn't really something we'd be able to officially support setting up and I wouldn't know what to suggest at this point.
Hopefully another community member will be able to assist you with the troubles you're having setting this up.
 Harry Beesley
