Port Forwarding - Sagemcom
mikeyue
Just moved from ADSL to Fibre (Sagemcom), with the same port forwarding rules (port 25 / 465 / 1723 / 993), all working fine on ADSL, but since the change to Fibre on Sagemcom, these ports are being dropped randomly, and also, the most bizarre thing is when I do a port scan from the internet, a whole bunch of ports are opened, including 21 / 22 / 110 etc, and I'm not even running any of these services, but I can connect to them 😞
So I'm forwarding all to the same server on a static IP (I've disabled dhcp & IPv6 on the router already), so what else can I do to fix this?Huh
thanks
