Port Forward
- Port Forward
Port Forward
22-10-2014 1:21 PM
Hi
Can anyone suggest the easiest COMBINED router to port forward please thanks
Message 1 of 3
(638 Views)
2 REPLIES 2
Re: Port Forward
22-10-2014 3:24 PM
Hi denny111,
From a man who's tried many routers I can tell you that the way you set up port forwarding doesn't tend to vary that much.
If you dip in to past posts in the fibre forum I'm sure you'll come across some recommendations.
I'd imagine you'll get some here before too long too.
Message 2 of 3
(421 Views)
Re: Port Forward
22-10-2014 7:21 PM
port forward.com is one of the best sites out there you will be an expert in no time
Message 3 of 3
(421 Views)
