Port 21 not stealthed
MartyPop
After doing a Shields-Up test on my one-week old TG582n, everything appears to be OK apart from port 21 (see attached screenshot).
How do I stealth port 21?
Fixes: 26
Re: Port 21 not stealthed
Use the PlusNET firewall.
Log into the portal, select connection settings and then the firewall option.
Fixes: 6
Disable the "FTP server" in the routers "content sharing".
Fixes: 62
can you be a bit more explicit as I can't see that option
Fixes: 6
I'm not using a TG582n at present so I'm going from memory:
Go to Home > Toolbox > Content Sharing  > configure:
Somewhere on that page there's a tick box to enable the routers FTP server -- remove the tick.
IF you can't find the setting, let me know and I'll plug in my tg582 and hopefully give better guidelines.
Fixes: 62
I wonder if that comes with updated firmware as mine shows and I am on 8.4.4.J but not fibre obviously
Fixes: 6
That GUI setting may not be present in routers without the USB port (the ones supplied for ADSL)
I haven't had one of those router to check.
If there's no USB port there's no use for a FTP server but that's no guarantee that Technicolor would disable the server.
IIRC the setting is present in older firmware version of Plusnet fibre routers.
DaveyH
Seasoned Pro
Fixes: 9
The port is closed, so does it really matter?
MartyPop
Quote from: npr
Thanks but it's already disabled (by default).
MartyPop
Quote from: Oldjim
I don't seem to be able to find the firmware revision but I can find the software version (10.2.5.2.FO)
MartyPop
Quote from: Townman
OK, done that, thanks:
With the setting at "Low", things were worse than with the firewall set to "Off"
With the setting at "High", all common ports are now stealthed (inc. port 21)
I'll leave it set at "High" for a while and see if I have any problems  Smiley
MartyPop
Quote from: DaveyH
Yes, it does matter (to me).
Fixes: 12
can you explain why it matters ?
MartyPop
Yes, indeed I can  Smiley
It's simply a matter of "The less that people see, the better"
Fixes: 12
ah so it's tin foil hat stuff then rather than anything else.
