Poor web interface on Fibre router
- Re: Poor web interface on Fibre router
26-08-2015 12:45 PM
I've just had my Fibre installed which works fine, but I must say I'm really disappointed with the web interface for the router.
- I cant see a way to change the LAN IP of the router which means Ive had to reconfigure all my devices which have static IP's
- I can't see a way to change the password for the web interface
- I can't see a way to change the DHCP pool addresses
- I really liked the device map on the ADSL router which showed which device was connected to which port. Vanished with the fibre router
- What's happened to the media sharing options?
I had all these features with the ADSL router. I don't understand why the router has been 'dumbed' down. We're not all newbies!
Message 1 of 5
(875 Views)
4 REPLIES 4
26-08-2015 1:49 PM
You can find additional options at http://192.168.1.254/expert_user.html
Message 2 of 5
(710 Views)
26-08-2015 4:28 PM
Quote from: Matthew You can find additional options at http://192.168.1.254/expert_user.html
Wahey! Now that's more like it!
Message 3 of 5
(710 Views)
08-03-2017 2:19 PM
Hi. The link doesn't seem to work, is there any new link I could access as the normal one has no way as many tools a normal person may need.
Message 4 of 5
(695 Views)
09-03-2017 12:20 PM
Which router do you have? The Plusnet ones are shown here https://www.plus.net/help/broadband/router-user-guides/
This thread is 2 years old so your router may not be the one that the OP was talking about.
Message 5 of 5
(661 Views)
