Poor upload speed
nigelhughes1954
Poor upload speed
My fibre download speed seems ok at about 34 Mbps but upload is painfully slow - less than 2 Mbps. It has been like this for over a month. Any ideas?
Fixes: 62
Re: Poor upload speed
Presumably you are on standard fibre not fibre extra so your speeds are up to 2Mb/s upload and up to 40Mb/s download
nigelhughes1954
Apologies! I was on the high speed fibre but recently dropped to standard fibre as the cost was getting ridiculous! Hadn't realised that the upload speed would be so low, I used to get similar speed on "normal" broadband!
