Poor speed
Pnd123
Poor speed
hi.
joined plusnet a little under a month ago, promising speeds of 45-61
what do i really get Huh 25.19 today.
we did see 45 once in the initial 10 day start up.
please advise.
Estimated line speed:61Mb (This may vary between 45.2Mb and 61.6Mb) - Current line speed:32.8 Mb
1. Product name: Plusnet Hub
2. Serial number:
3. Firmware version: Software version 4.7.5.1.83.8.217.1.1 Last updated Unknown
4. Board version: Plusnet Hub One
5. DSL uptime: 10 days, 22:33:21
6. Data rate: 10221 / 39620
7. Maximum data rate: 10258 / 40934
8. Noise margin: 6.4 / 6.9
9. Line attenuation: 24.8 / 18.3
10. Signal attenuation: 24.7 / 16.3
11. Data sent/received: 4.9 GB / 48.1 GB
12. Broadband username:
13. 2.4 GHz Wireless network/SSID: 2.4
14. 2.4 GHz Wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s))
15. 2.4 GHz Wireless security: WPA2
16. 2.4 GHz Wireless channel: 6
17. 5 GHz Wireless network/SSID: 5
18. 5 GHz Wireless connections: Enabled (802.11 a/n/ac (up to 1300 Mb/s))
19. 5 GHz Wireless security: WPA2
20. 5 GHz Wireless channel: 44
21. Firewall: Default
22. MAC Address:
23. Modulation: G.993.2 Annex B
24. Software variant: AA
25. Boot loader: 1.0.0
Fixes: 31
Re: Poor speed
Your sync speed is below the estimate you have quoted, have you plugged the router into the master or better still test socket? If your sync speeds improve then the reduction is due to your internal wiring, if it stays the same then you should report a fault.
MrSilver
Fixes: 9
Re: Poor speed
What do you get on http://speedtest.btwholesale.com/
Then run further diagnostics and let us know what's on there and then run test 3 too which bypasse plusnet network too.
You should be getting faster speeds based on your estimate.
Pnd123
Re: Poor speed
direct connection into master.
1. Best Effort Test: -provides background information.
  Download Speed
  41.41 Mbps
0 Mbps 42.26 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 41.41 Mbps
 For your connection, the acceptable range of speedsis 29.58 Mbps-42.26 Mbps .
 Additional Information:
 IP Profile for your line is - 42.26 Mbps
  Upload Speed
  1.71 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 1.71Mbps
Browni
Aspiring Hero
Fixes: 45
Re: Poor speed
That is faster than what your router stats showed before, what are they now?
I must have been really bad in a previous life. This is my 3rd ISP in a row that uses lithium.
Now you lot are going to suffer because my current ISP doesn't run a forum Cheesy
MrSilver
Fixes: 9
Re: Poor speed
Thanks, can you also show the output of https://www.dslchecker.bt.com (remove you telephone number!)
Pnd123
Re: Poor speed
2. Serial number:
5. DSL uptime: 0 days, 00:21:47
6. Data rate: 10327 / 39319
7. Maximum data rate: 10315 / 39278
8. Noise margin: 6.4 / 5.9
9. Line attenuation: 24.6 / 18.3
10. Signal attenuation: 24.5 / 16.2
11. Data sent/received: 2.6 MB / 25.7 MB
22. MAC Address: 24:20:c7:53:22:76
vdsl clean high 66.5    low 49
impacted high  52.7    low 30
thanks for helping
Fixes: 16
Re: Poor speed
Do you have, and are you using, the test socket?
Did you do the speedtest in the test socket, but then plug it back in as it was before?
Pnd123
Re: Poor speed
Last speed test was done in the master socket, i got 40.tried it wireless got 38. But i noticed the line profile was set at 40.
Fixes: 16
Re: Poor speed
By master socket, do you mean test socket?
See http://www.kitz.co.uk/adsl/socket.htm
Pnd123
Re: Poor speed
Test socket.
The one behind the plate
Fixes: 31
Re: Poor speed
What about the answer to @MrSilver question?
Fixes: 16
Re: Poor speed
Were the second set of stats from the Hub One taken while in the test socket?
Pnd123
Re: Poor speed
Yes second results are from the test socket
