Poor speed and no line estimate
khile
poor speeds last 24 hours have made my connection fall from around the 78mb mark to 2-5mb i have tried restarting router and manually disconnecting via the router interface but speed very rarely returns and when is does its only for a short time
i tried using bt's speed tester but got error " The Performance Tester is currently unable to run a speed test for your broadband connection. Please try again shortly, however if this problem persists, raise the issue with your service provider." and now plusnet shows my speed as Estimated line speed:
Could these be looked at too as unable to run diagnostics i spoke to someone on via chat and they said my broadband order might not have been closed off properly with supplier?
Cheers
Fixes: 236
Re: Poor speed and no line estimate
Our tests aren't showing any issues.
Is this over a wired or wireless connection?
 Matthew Wheeler
khile
Its over wired and via home plugs. Both give same results
Fixes: 36
You really need to test with wired directly to the router to eliminate interference via the Homeplugs.
khile
I have tried both wired directly to  router and it gives same results.
Weirdly if i reset router full speed returns but only for short time
cedlor
Quote from: khile
So were they going to do something about it?  have they raised a ticket?  If neither I would ring them again.
wwex786
Quote from: khile
I have the exact same problem as you. Every time I reset my PlusNet hub I get full 35mb/s as I should be getting. but after like 10 minutes it goes down to 5-7mb/s !  Sad
