Poor fibre speeds
- Poor fibre speeds
Poor fibre speeds
25-04-2015 9:06 AM
Re: Poor fibre speeds
28-04-2015 7:33 PM
28-04-2015 7:46 PM
https://www.btwholesale.com/includes/adsl/adsl.htm?s_cid=btw_furl_adslchecker_applications_diagnosti...
http://speedtest.btwholesale.com/
http://www.thinkbroadband.com/speedtest/speedtest2.html
post em to http://imgur.com/ and then post the BB links back to us
Edit: Example
28-04-2015 7:58 PM
28-04-2015 8:02 PM
28-04-2015 8:04 PM
28-04-2015 8:04 PM
28-04-2015 8:22 PM
28-04-2015 8:23 PM
28-04-2015 8:40 PM
28-04-2015 8:48 PM
How long is your line, any idea ?
28-04-2015 9:34 PM
no idea how long my line is
28-04-2015 9:58 PM
you can just post the text from your plusnet profile.
28-04-2015 10:29 PM
Estimated line speed:
60Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2015-04-10 16:33:11
Current line speed:
30 Mb
28-04-2015 10:57 PM
Thanks for taking the time to post all that information.
I can see that you have been advised of 60Mbps and that you are only receiving 30Mbps, I'm sure one of the plusnet team will look over this in the morning and will advise if you need to raise a ticket for them to look into this further or not.
