Poor fibre speeds
- Re: Poor fibre speeds
Poor fibre speeds
11-07-2018 8:11 PM
12-07-2018 9:29 AM - edited 12-07-2018 9:30 AM
Hi @Sr,
I'm sorry to hear that you've been experiencing poor speeds. I've tested your line today but the test isn't picking up the cause of this issue and indicates that your line is currently syncing at 45.5mbps. For reference, today's test result is as follows:
GEA Test Detail | |||
Circuit ID | NA | Service ID | BBEUXXXXXXXXX |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
Description | GEA service test completed and no fault found . | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 45.5 Mbps | ||||
Upstream Speed | 5.2 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Not Detected | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Estimated Line Length In Metres | 788.0 | ||||
Upstream Rate Assessment | Low | ||||
Downstream Rate Assessment | Good | ||||
Interference Pattern | Regular Interference Observed Daily | ||||
Service Impact | Retrains Observed | ||||
Interference Duration Longest Occurrence | From 16:15 to 16:45 | ||||
Interference Location | Customer Premise | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL | ||||
Profile Name | 0.128M-80M Downstream, Interleaving Low - 0.128M-20M Upstream, Error Protection Off |
Are the poor speeds solely occurring on wireless connections or are they occurring on wired connections too?
12-07-2018 1:02 PM
12-07-2018 1:12 PM
Hi @Sr
Thanks for coming back to us and thanks for the screenshot.
All of the speed tests that you've performed have been done so via a wifi connection.
Could you please run a speed test via a device that is connected via a cable to the router and let us know the outcome? Wifi can be affected by any number of factors and we'd need to identify whether your speed concerns exist on both wifi and wired in order to progress this for you.
Best wishes,
Dave
