Poor Speeds
- Poor Speeds
Poor Speeds
17-02-2015 9:34 PM
Well, looks like after the honeymoon period of good speeds, everything has dropped considerably.
After a quick Speedtest i now get...
This is with a 70mb connection and usually getting 67mb D/L, but also noticed upload has dropped considerably.
Is this something i need to open a fault for?
EDIT: just checked my gateway and at some point it has jumped to a much poorer one.
Why does this keep happening, especially when i havent rebooted the modem or anything?
Message 1 of 5
(670 Views)
4 REPLIES 4
Re: Poor Speeds
17-02-2015 10:39 PM
It happens when you have a PPPoE disconnect. Check the uptime on your router page
Message 2 of 5
(373 Views)
Re: Poor Speeds
17-02-2015 11:27 PM
Thanks for that, buti rebooted the router (im using an Asus) before checking.
However, checking the log i am getting multiple lines of...
"kernel: eth1: received packet with own address as source address"
These seem to have started a day or so ago.
Would the reason be that i have just added a powerline to clone and extend the wifi?
Message 3 of 5
(373 Views)
Re: Poor Speeds
18-02-2015 9:58 AM
I assume the test itself was run wired?
Also that you know the sync speed is still high (eg from modem stats or BT wholesale speedtest)?
You don't say if the Asus router is a combined modem/router or if you are using an Openreach modem.
Seems easy enough to disconnect the powerlines temporarily and see if that has any effect.
Message 4 of 5
(373 Views)
Re: Poor Speeds
18-02-2015 11:05 AM
Have a read through this https://www.avforums.com/threads/asus-rt-n66u-help-please-received-packet-with-own-address-as-source...
They seem to have had the same problem as you and it sounds like its due to wifi extenders.
Message 5 of 5
(373 Views)
