Poor Speed, Large Pings
khile
Hi all been having a few issue with broadband pings going from as low as 1 to as high has 125+ and my speed is roughly having from 80 to around 35-40
Fixes: 76
Re: Poor Speed, Large Pings
Hi khile,
Tests aren't showing an obvious issue but I can see this happened the other day from this post: http://community.plus.net/forum/index.php/topic,142792.msg1259190.html#msg1259190
Mind letting me know what resolved that?
 Adam Walker
khile
Hi there was no obvious issue it just seemed to resolve itself but now its come back ive done a speed test now and seems to be fine.
the issue seems to start around 2pm and continue well into the night
Fixes: 76
No worries khile,
Do you usually connect over wireless or ethernet?
If its the former please run a speed and a ping test whilst connected with a network cable.
Hope that doesn't continue to be an issue for you!
Adam
 Adam Walker
khile
Always wired
current speed test shows
71 up and 19 down
there does not seem to be any cause for it to happen pings higher then usual of around 5 its currently 17
