Poor Fibre Speeds, not happy :(
- Re: Poor Fibre Speeds, LESS than contracted!
28-09-2015 4:05 PM
I have run the BTw performance test as well as an Ookla and TBB speedtest.
Starting with the BTw performance check, the results are as follows:
BT Wholesale Broadband Performance Test
Broadband Speed Test Results
Download Speed (Mbps): 9.11
Upload Speed (Mbps): 9.25
Ping Latency (ms): 51.88
The "Further Diagnostic" test results (as copied and pasted fdirectly from results page) are;
Results Image not loaded
1. Best Effort Test: -provides background information.
Download Speed
10.89 Mbps
0 Mbps 51.82 Mbps
Max Achievable Speed
Download speedachieved during the test was - 10.89 Mbps
For your connection, the acceptable range of speedsis 41.45 Mbps-51.82 Mbps .
Additional Information:
IP Profile for your line is - 51.82 Mbps
Upload Speed
4.96 Mbps
0 Mbps 20 Mbps
Upload speed achieved during the test was - 4.96Mbps
This test was not conclusive and further testing is required.This might be useful for your Broadband Service Provider to investigate the fault.
If you wish to carry out further tests,please click on 'Continue' button.If not, please close the window using 'Exit' button and contact your ISP for further assistance with these results.
Ookla speedtest Result:
http://www.speedtest.net/result/4700571561.png
TBB Speed Test:
What on EARTH is going on Plusnet? Up until today, my speeds have been good, yet all of a sudden this?
AND........The details from my router...
DSL Firmware Version 1.0.2.9
DSL Driver Version FwVer:5.5.1.131_B_A60901 HwVer:T14.F7_0.2
DSL Link Status up
DSL Uptime 5 days 14 hours 37 minute(s) 13 seconds
DSL modulation ITU G.993.2(VDSL2)
ANNEX Mode ANNEX B
SNR Down 4.5 dB
SNR Up 6.0 dB
Line Attenuation Down 17.4 dB
Line Attenuation Up 3.2 dB
Path Mode(downstream) Interleaved
Path Mode(upstream) FastPath
Data Rate Down 53533 kbps
Data Rate Up 15732 kbps
MAX Rate Down 72952
MAX Rate Up 15449
POWER Down 12.7 dbm
POWER Up 8.1 dbm
CRC Down 11100
CRC Up 2260
28-09-2015 4:20 PM
28-09-2015 4:26 PM
Phone exchange:
EDMONTON
Estimated line speed:
35Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2015-08-06 10:16:43
Current line speed:
40 Mb
Still not getting corerect speed. Tested it by connecting direct to router/modem, wireless off, no other connections.
****EDIT****
Just as an aside, the router/modem is connected directly to the master, thence to a cat6 line to a computer and 8 port switch in another room under "Normal" circumstances".
The above results were collected using my laptop connected by Cat6 patch lead direct to the router/modem itself.
Results using the Cat6 line to the other room fall within a +/- 3mb differential, which I find as acceptible, even though to many it might not be.
****EDIT****
28-09-2015 4:27 PM
28-09-2015 4:31 PM
28-09-2015 6:55 PM
Is there a possibility this can be rechecked and the data updated as it is over 7 weeks since last check?
Also, can a member of PN staff look into these issues please?
Re: Poor Fibre Speeds, not happy :(
01-10-2015 7:36 PM
01-10-2015 7:41 PM
01-10-2015 10:09 PM
01-10-2015 11:25 PM
Quote from: baldrick ... if you go to page 34 in Fibre it is the second one down titled 'Fibre installed today - slow connection'.
For convenience, here's the link to reply #4 in that topic. http://community.plus.net/forum/index.php/topic,139636.msg1231596.html#msg1231596
04-10-2015 1:22 AM
04-10-2015 8:21 AM
