Poor FTTC speeds
- Re: Poor FTTC speeds
Poor FTTC speeds
01-05-2016 10:32 PM - edited 01-05-2016 10:34 PM
My FTTC speed is a joke to be honest, my 3G is faster than my connection, with a BTWholsale speed test I am getting 9.6Mbps down & 0.37Mbps up. there is a BT Openreach cabinet opposite my house, is this the best I should expect ?
PlusNet can you help please ?
02-05-2016 9:15 AM
Your line is performing slightly below the estimates of 13.1 to 18.4Mbps, with it currently in sync at 12.2 Mbps.
It's worth completing the fault checker you started just to see if anything else can be done to improve that last little speed from the line.
04-05-2016 10:51 PM
Well if this is the best 21st century fibre broadband can offer then PN are not all the seem to be cracked up to be. I cannot game while someone else in the house is on youtube. There is a new OR cabinet outside my house but it seems far to ridiculous to be connected to that. Thanks PN!
04-05-2016 11:00 PM
Hello,
You state a cabinet is opposite your house, do you know where the PCP cabinet is?
If you Like it, give it a
04-05-2016 11:30 PM
05-05-2016 7:54 AM
It's very likely it'll be serving another street, it's possibly serving the road where you're current cabinet it.
You'll unlikely to be moved to this cabinet unfortunately.
05-05-2016 12:19 PM
