Plusnet self install coming very soon?
BT Wholesale announced yesterday they are commercially launching two new commercial fibre products from 1 June:
- FTTC Self Install
- FTTC Managed install using a Customer Provided Modem/Router.
Will Plusnet be launching their self install service on the back of this (assuming they have a working and conformity passed FTTC modem/router)?
Fixes: 167
Re: Plusnet self install coming very soon?
No news at the moment I've afraid, when we have something to announce we'll make sure to tell you.
 Chris Parr
 Plusnet Staff
Fixes: 62
can you clarify what is meant by - FTTC Managed install using a Customer Provided Modem/Router. - as a managed install implies that an engineer will attend and that the ISP will provide the modem instead of him arriving with it
@ Chris - We await with eager anticipation.
@ Oldjim - That's what it will be. The engineer will fit the VDSL front plate to the NTE5 and use the ISP supplied router/modem instead of supplying an OR modem.
Fixes: 62
so is that in addition to the existing managed install until September (I thought I remembered that date) when it will be withdrawn
OR have extended it a bit, so from 1 Jan 2016 they will no longer supply OR modems for new installs. However, they will continue to support the existing OR modems (i.e. replace faulty ones as part of a repair fault) until 1 Jan 2017.
Fixes: 62
thanks - that means that I will - no doubt - get a BT Modem
Note to self
Make sure I can spot the difference between an Ecl and Huwai unit
Fixes: 4
It's all in the spelling Jim.  Roll eyes
Fixes: 62
Very true  Grin Grin which is why I will use this to check https://support.aa.net.uk/FTTC_Modem
