Plusnet router broken
dougle25
Hi
Can someone please tell me if Plusnet will give me a free router , as the one I have is broken. It is one that plusnet gave me when I went to fibre. Plusnet Sagemcom 2704N Wireless Router. Its the one that stand up.
Gel
Seasoned Pro
Fixes: 12
Re: Plusnet router broken
dougle25
 its a good 2 years + old
JayG
If you are out (or nearly out) of contract a new 2704n will just cost the £6.99 postage IF you sign up to a new contract (otherwise it's £40 plus the postage.)
BrightonRock
Fixes: 4
You do have other options including buying your own router and moving to another ISP that will provide a router for free.
I have never understood why PlusNet's policy in this situation was to encourage exit by charging full price for their replacement router. If you stay, you can probably buy something better than the PlusNet offering in any case.
dougle25
Can I buy any router ?   will this one do         http://www.argos.co.uk/product/1227291
Thanks for your help
Happy Christmas
MrSilver
Fixes: 9
To be honest I have never seen an ISP give you a free router 2 years after taking service, unless you go to a new contract then you tend to get a new router in free again. If you re contract you would get the new Hub1 which some hate but I think its got pretty decent wifi and been quite stable.
If you look at hte lieks of SKy, if your STB dies after warranty you are buying a full price new box etc.
bill888
Seasoned Pro
Fixes: 21
yes, the TL-WR841n is comparable to the 2704n, will work with existing Openreach fibre modem.  You will need to manually enter your full plusnet username (eg. username@plusdsl.net) and password.
Just log into new router using web browser, and run Quick Setup.  Choose 'PPPoE/Russian PPPoE' option.
TL-WR841n emulator:
http://static.tp-link.com/resources/simulator/TL-WR841ND_V10/Index.htm
If you wish to eliminate the Openreach modem, then you can purchase a new router which must have a built in VDSL modem, but these will cost considerably more.
BrightonRock
Fixes: 4
A fair point.
But PlusNet only give 12 month guarantee on their routers even if one has a 18 month or 24 month contract. BT will (or at least used to) replace a router for free any time if one were still in contract.
Also PlusNet don't legally sell you the router: it is free. If one bought a router, legislation would probably provide that the guarantee would be longer.
