Plusnet internal networking issue
- Plusnet internal networking issue
15-12-2020 4:28 PM - edited 15-12-2020 4:30 PM
Each time it's raining my internet speed is dropping and there ping time to 2nd host is jumping really high.
Tracerote from my router (195.166.130.248 is my default gateway):
# traceroute www.google.com
traceroute to www.google.com (172.217.169.68), 30 hops max, 38 byte packets
1 195.166.130.248 (195.166.130.248) 6.919 ms 11.452 ms 8.341 ms
2 84.93.253.71 (84.93.253.71) 154.917 ms 84.93.253.67 (84.93.253.67) 89.145 ms 178.098 ms
3 195.99.125.140 (195.99.125.140) 161.846 ms 195.99.125.144 (195.99.125.144) 167.902 ms core1-BE1.colindale.ukcore.bt.net (195.99.125.132) 171.513 ms
4 peer8-et-3-0-1.telehouse.ukcore.bt.net (109.159.252.154) 165.363 ms peer8-et-7-0-1.telehouse.ukcore.bt.net (109.159.252.104) 166.745 ms 194.72.16.226 (194.72.16.226) 176.412 ms
5 109.159.253.3 (109.159.253.3) 171.771 ms 109.159.253.189 (109.159.253.189) 178.467 ms peer5-te0-0-0-32.telehouse.ukcore.bt.net (195.99.126.77) 174.789 ms
6^C
Sound like internal Plusnet networking issue.
Does anyone experienced something similar ?
If I say this to helpdesk people, they have no clue what I'm talking about
Re: Plusnet internal networking issue
15-12-2020 5:43 PM - edited 15-12-2020 5:43 PM
I’d highly doubt it’s a plusnet networking issue if the problem happens when it rains. More likely to be an Openreach infrastructure fault.
Also its normal to see some packet loss when running a traceroute as some servers are going to be prioritising the routing of traffic rather than responding back to your ping requests.
Have you raised a fault at faults.plus.net for further investigation?
on
16-12-2020
11:12 AM
- last edited on
16-12-2020
1:15 PM
by
Strat
I suspect that this is Openreach but IPs belongs to Plusnet range according to whois:
$ whois 195.166.130.248|grep "descr:"
descr: Core Loopback Addresses
descr: PlusNet plc.
descr: PlusNet plc.
$ whois 84.93.253.71|grep "descr:"
descr: Core Infrastructure
descr: PlusNet plc.
I don't think that these are servers responding. Mostly are routers (interfaces in routers) as I referring to time between 1st and 2nd hop.
When is not raining all works as expected:
root@router:~# traceroute www.google.com
traceroute to www.google.com (216.58.212.196), 30 hops max, 38 byte packets
1 195.166.130.248 (195.166.130.248) 7.849 ms 6.246 ms 7.757 ms
2 84.93.253.71 (84.93.253.71) 7.943 ms 7.590 ms 84.93.253.67 (84.93.253.67) 8.584 ms
3 core1-BE1.colindale.ukcore.bt.net (195.99.125.132) 7.623 ms 195.99.125.144 (195.99.125.144) 8.401 ms core1-BE1.colindale.ukcore.bt.net (195.99.125.132) 9.120 ms
4 peer2-et3-1-4.slough.ukcore.bt.net (62.172.103.220) 26.280 ms 14.833 ms 194.72.16.74 (194.72.16.74) 35.301 ms
5 peer5-te0-0-0-32.telehouse.ukcore.bt.net (195.99.126.77) 8.542 ms 8.669 ms 109.159.253.185 (109.159.253.185) 9.810 ms
6^C
"Also its normal to see some packet loss when running a traceroute as some servers are going to be prioritising the routing of traffic rather than responding back to your ping requests. "
Linux traceroute don't use ICMP ....
There is packet loss as well when I ping 2nd hop. 1st hop which is my DG is not pingable, 2nd is and for 10 pings usually 2 are lost.
Moderator's note by Dick (Strat): Post released from Auto Spam Filter.
16-12-2020 8:27 PM
Yeah the IPs belong to Plusnet but rain will have no effect on Plusnet’s network equipment because I imagine it’s nowhere near where you live.
19-12-2020 10:56 AM
I will wait for next rain and open ticket with Plusnet.
Most of my traffic when I work is text terminal sessions so I don't use much bandwidth but rest of family is video/game oriented and this become a issue. During meetings voice/video is starting cracking which is not good as well.
