Plusnet installation - Help
- Re: Plusnet installation - Help
11-02-2015 7:56 PM
Hello I'm new to plusnet, a BT engineer is due to come tomorrow to activate/install my fibre broadband service
I was wondering if it would be an option for him to fit it in a upstairs room? As that is where a laptop will be wired using Ethernet rather than wireless.
I have recieved my wrouter in the post.
Cheers
Cheers
Message 1 of 5
(720 Views)
4 REPLIES 4
11-02-2015 8:42 PM
That depends on whether you requested the extension kit when you ordered it
Message 2 of 5
(398 Views)
11-02-2015 9:28 PM
As Jim says, it does depend on whether or not you ordered an extension kit. I assume that you didn't, therefore I suggest that you sweet talk the engineer & maybe make it worthwhile for him to do it. Otherwise if you have it done retrospectively it will cost approximately £150.00.
Message 3 of 5
(398 Views)
12-02-2015 8:44 AM
Thanks to you both
Message 4 of 5
(398 Views)
12-02-2015 10:05 AM
Normally they will only run simple cabling. You may do better to have him install the modem at the 'natural' place and run your own ethernet cable to the router in the upstairs room.
The extension cable will have a detrimental effect on VDSL speeds; though that is usually insignificant.
Message 5 of 5
(398 Views)
