Plusnet hub one internet connection died, orange glow
FIXEDTopic Options
- Plusnet hub one internet connection died, orange g...
11-08-2020 8:41 PM - edited 11-08-2020 8:42 PM
Hello
I've been a customer for nearing 4 years now. Today at 5:30pm I had the dreaded orange glow of death and it hasn't resolved itself like it usually does in around 5 10 mins.
Admin page on the hub trieas to connect but fails. Nothing in the logs apart from a strange issue regarding the log timestamps; they appear to start from midnight 08 Nov each time tha hub restarts.
In the logs I note it tries to connect to https://dbtpnhdm.bt.mo and then logs it could not resolve host. If the hub datetime is screwed it might be failing to negotiate https
To make things worse I use lastpass to manage my credentials and it needs online access to work. Which means I can't log into my plusnet account to raise a ticket.
If I reset my plusnet account password is that the same password the hub uses to authenticate with plusnet?
Fixed! Go to the fix.
Message 1 of 4
(600 Views)
3 REPLIES 3
Re: Plusnet hub one internet connection died, orange glow
11-08-2020 9:32 PM
I have now got into my plusnet account. But I can't see where you raise a ticket?
Message 2 of 4
(578 Views)
11-08-2020 9:50 PM
They dropped that feature some years ago.
Try links below.
Try links below.
Message 3 of 4
(569 Views)
11-08-2020 10:19 PM
After many many reboot attempts, one of them finally fixed the issue, and what do you know the log timestamps are now correct.
Am going to look into getting a replacement hub, the last firmware update this one has had was in Feb 2019... yay secure.
Message 4 of 4
(559 Views)
