Plusnet hub 2 router: How to use WAN port as LAN port 4 (and check/update firmware)
FIXED- Subscribe to RSS Feed
- Plusnet hub 2 router: How to use WAN port as LAN p...
19-01-2022 12:14 AM
As I understand it, this router is the same as the BT SH2. That router can be configured to use the WAN port (part of a yellow block of RJ45 sockets but with a red WAN label) as an additional LAN port when you are using the RJ11 socket for your FTTC internet.
But I can't find that setting in the admin interface?
Also I can't see how to check or update the firmware for the router from the admin interface?
Fixed! Go to the fix.
19-01-2022 7:38 AM
The hardware may be the same ad the BT SH2 but the Plusnet firmware is different and zAFAIK does not have the option to use the WAN port as a LAN port.
Firmware updates are automatically pushed to the router when they become available.
Re: Plusnet hub 2 router: How to use WAN port as LAN port 4 (and check/update firmware)
19-01-2022 8:07 AM - edited 19-01-2022 8:08 AM
