Plusnet fibre broadband does not cope with uploads and will disconnect you...
- Plusnet fibre broadband does not cope with uploads...
Re: Plusnet fibre broadband does not cope with uploads and will disconnect you...
04-05-2017 12:03 PM
Hi Bob, new router arrived and installed. S/N xxx0355 User telegraphhill
Could you try to update again, please?
05-05-2017 9:47 PM - edited 06-05-2017 9:21 AM
I have a Plusnet Hub One - reported a fault 05/05/17 where my line has suddenly started dropping out frequently in the past couple of days (every 15 minutes or so) having previously been "up" for 51 days (and overall extremely stable). Your tier 1 support said the line is testing fine, and has got me currently connected to the test socket on a new filter etc, although this made no difference at all to the drop outs. The fault ticket has been passed to your faults team apparently.
On doing some further research after reporting the fault, I realised that we have added a number of large files to backup to Azure in the past few days - and so the upload has been maxed out for the past couple of days, possibly matching when the dropouts started. Having set a throttle to the upload (to 1.5MB/sec, on an 80/20 line) to see what difference this makes,.the line has now been stable 12 hours.
Looking at the router event logs, there is an entry "PPP LCP Send Termination Request [PPPoE PADT received]" immediately before each drop out, which I think matches the circumstances described in this thread.
If I am reading this thread correctly, this issue is likely to be the same as that described in the thread and a config change you can apply from the plusnet side will resolve it so I can actually use my full bandwidth (with a permanent fix to come by firmware later in the year)?
Look forward to an update - thanks for any assistance.
08-05-2017 1:22 PM
I have the same symptoms and same router with the same software version. Would it be possible to apply the fix to my router please because the intermittent drop outs are causing me problems in trying to find a new job. I can't seem to get it stable when searching in JobServe.
I don't know how to PM you though if you need anything further from me.
08-05-2017 1:43 PM
@Tainshy-Stryder, @Telegraphhill & @mjl1 - I've just pushed a config update to each of your devices so you should find things are a lot better now.
on 08-05-2017 6:18 PM - last edited on 08-05-2017 6:25 PM by Mav
I still get restarts every 24-48 hours. The longest uptime since we spoke was 51hours.
Moderator's note by Mike (Mav): Post released from Spam Filter
08-05-2017 6:48 PM
Not going to be related. I can see the drops, but they don't coincide with times of heavy upload
Session Started Session Ended Session Duration 20:44 07/May/2017 N/A 21:56:56 (on going) 12:10 05/May/2017 20:43 07/May/2017 2 Days, 8:33:18 02:48 04/May/2017 12:09 05/May/2017 One Day, 9:21:8 19:20 02/May/2017 02:48 04/May/2017 One Day, 7:28:2 01:10 01/May/2017 19:19 02/May/2017 One Day, 18:9:22 03:40 29/Apr/2017 01:09 01/May/2017 One Day, 21:29:13
09-05-2017 7:24 AM
Hi Bob,
We spoke previously on here and you kindly confirmed the fix had been pushed out to me in mid March. Since then I have had drop outs on the 1st April (Twice in quick succession) and the same again last night the 8th May (twice again in quick succession).
Now this is not a major inconvenience compared to some, but is this 'expected' behaviour and something I should just shrug off - or should I troubleshoot further? I had thought it was all good until last night?
Since the first problem I experienced and reported (on a daily basis for three days in December) I have been plugged into the test socket directly on the only telephone Point I have (master) with a new filter.
One last question - if I power off the router, for whatever reason (I don't intend to), will the fix still apply? I assume I only wipe it if I do a factory reset.
Cheers,
James
09-05-2017 1:31 PM
Hi @jamestapp, I can see a few drops on your connection but they don't seem excessive and I don't believe they are related to the problems that were being discussed in this thread.
If the drops start becoming problematic and you've been through our troubleshooting guides, by all means feel free to raise a fault over at http://faults.plus.net
However as the drops appear to be quite infrequent, it may not be anything to worry about.
09-05-2017 1:42 PM
Hi Harry,
Thanks for the quick reply. I did suspect it might be something less catastrophic than the fault some of the others are experiencing.
"it may not be anything to worry about"
That's the key issue for me - Is it normal or do I need to take some action? I can live with the current frequency as long as it doesn't die completely one day - I was told via the fault resolution that was closed around xmas (no dropout for a week after daily problems) that it had to be dropping 3 times a day regularly to warrant an engineer visit?
I assume if I log a fault with my current monthly frequency of drop out you will not send an engineer?
Regards,
James
09-05-2017 1:50 PM
@jamestapp wrote:
I was told ... that it had to be dropping 3 times a day regularly to warrant an engineer visit?
That's more of guideline than a strict rule, as a drop or two could be almost anything, but wouldn't necessarily suggest there is a fault on the line.
Testing your line isn't indicating any problems, so if we were to raise this with our suppliers and they were unable to find anything from further testing, they'd likely request to send an engineer.
Having said this, if the engineer came out and said there was no fault with the service, the appointment would become chargeable, which is why we wouldn't just want to jump straight in to this off the back of one or two drops now and then.
09-05-2017 2:24 PM - edited 09-05-2017 2:25 PM
Thanks again for the quick reply,
I'll continue to monitor it and if it gets worse I'll raise a ticket. I'm using the test socket with a new filter, and the router is in warranty, so I can't see why it would be a problem here - But I understand you wouldn't want to pay for an Open reach engineer if the problem does not manifest itself more regularly. Our housing estate/exchange has not been fault free over the years, my broadband failed completely in the year before I went to fibre - and the fault was repaired speedily by yourselves/open reach.
I suppose complete failures are easier to deal with in some ways.
Regards,
James
09-05-2017 3:09 PM
Although we would be charged, £65 of this charge would be passed on to yourself, and we wouldn't want you to to incur and engineer charge if the engineer confirms there is not actually a fault on the line.
That sounds like the best option at the moment
09-05-2017 8:23 PM
Hi @bobpullen,
You sorted me out a while ago, and since then I have upgraded to 80/20. However, I have just started experiencing drop outs again!
Please could you look into it? username is csjkeir.
Many thanks,
Chris
09-05-2017 8:38 PM
@bobpullen - worth mentioning that I have checked the logs, and the 'send termination request' hadn't happened at all after your config change, but kicked in again as soon as the 80/20 upgrade completed.
Thank you,
Chris
09-05-2017 8:58 PM
