Plusnet fibre broadband does not cope with uploads and will disconnect you...
- Re: Plusnet fibre broadband does not cope with upl...
Re: Plusnet fibre broadband does not cope with uploads and will disconnect you...
11-02-2018 10:44 AM
I can't believe this bug-ridden piece of [-Censored-] BT hub still hasn't been fixed.
I'm on the lookout for a decent hub such as an Asus DSL-AC68U.
11-02-2018 11:24 AM
Problem went away with mine when it was upgraded which I think adds a QoS ruleset. All is fine now. The hub is pretty good for a freebee, be nice if it had guest network, traffic stats, SNMP, but you can't have everything for nothing.
15-05-2018 3:41 AM
Over the last month, I've seen several random PPP drops, occurring rarely and at random but enough that they have disconnected game sessions. They are always of this form:
PPPoE is down after 3272 minutes uptime [Disconnected]
PPP LCP Send Termination Request [Peer not responding]
The disconnections last for about 90 seconds and then the PPP link comes back up.
I saw the thread and am wondering whether it applies. I have what I think is the latest router firmware:
Plusnet Hub One | Software version 4.7.5.1.83.8.237.2.2 | Last updated Unknown
We used to get unreliability during rainy weather so line problems are not impossible. Still, is it possible to have a quick look at the account and see if there is any obvious cause for these disconnects. If the router's settings need to be adjusted to prefer stability to superfluous speed then of course this is what I'd like. As I am playing online games, the upload speed remains important.
I can send any further information you might require if you PM me.
We renewed the contract and got a new router in the last month or so but did not change the actual broadband package.
Thanks!
18-05-2018 4:37 PM
@bluewhale wrote:
What's important, is that your line eventually stabilises if the Hub One is left in place - even if that means a target SNR of 6db rather than 3db, and a lower sync rate.
but that's the point my line does NOT stabilise, if i use the hub one then i get instability on a perm basis, the DLM does not put it back to 6db and changing the stability profile had no effect either
it's like you are in denial and are back to trying to blame conditions on my line which do not exist as the openreach modem has proven
i wonder how many people are suffering without realising this, it was an issue for us because of the youview box
i would have thought someone should be trying to find out what is going on rather than just ignoring me...
@bluewhale, I think we might have a fix for this now. Fancy trying an updated firmware build for me?
@Toft, sorry I don't think this thread is relevant as you're already on the latest firmware build.
18-05-2018 5:12 PM
@bobpullen yes if you like, what do i need to do other than switch the router back to using the telephone connection? how long will it take etc
18-05-2018 5:20 PM
Should I start a new thread, or do you have the ability to look at these disconnects from your end? They are persisting, approximately daily, but not at any given time. Thanks.
18-05-2018 5:27 PM
@Toft, yep, or get a fault ticket opened at http://faults.plus.net
@bluewhale, will drop you a PM...
18-05-2018 5:45 PM
I just tried now and at the last stage, got:
"Broadband Troubleshooter - Error
There's been a problem
Please try using the Broadband Troubleshooter again in a short while. If you continue to have problems please contact our Support Team for help."
I'll try again another day.
25-05-2018 2:32 PM
Hi Toft,
I can see you did report a fault, we're just awaiting your response to that at the moment.
Here's a direct link: https://www.plus.net/wizard/?p=view_question&id=174926191
25-06-2018 10:10 PM
Bob,
I am getting almost daily disconnects (PPP LCP Send Termination Request [User request]) using the Plusnet router that I never get using the Plusnet router in conjunction with an Openreach modem.
I understand there is a configuration change required in the router to resolve this?
How do I go about getting this configuration change?
Regards
26-06-2018 10:07 AM
26-06-2018 7:59 PM
26-06-2018 9:43 PM
Firmware version as follows...
Plusnet Hub One | Software version 4.7.5.1.83.8.237.2.2 | Last updated 11/08/17
Thanks,
28-06-2018 11:04 AM
Bob,
Any update on this? Did you receive the firmware version I am running?
This disconnect happened again this morning. It is something peculiar to the Hub One as if I use an Openreach modem instead of the Hub One's built in modem (but still use the HUB one as a wifi router via the WAN port), then I rarely disconnect and can stay connected for months at a time.
Would be grateful to know your thoughts on this.
Thanks.
30-06-2018 5:43 AM
It doesn't sound like the upload issue discussed in this thread. "[User request]" is a fairly generic reason that could indicate the VDSL2 link disconnected. Do your logs indicate the VDSL2 link is disconnecting?
